Probe result for a specific location
    • Ramy12
      Hi, I?m not sure this is the right section for a question like this. I hope someone con help me anyway. nIs there any way to get a probe result for a specific element or note not just a line, surface or body? I would like to know the temperature at a specific location of one body over the period of a full process. nThanks!n
    • Govindan Nagappan
      Hi Array nFor temperature at specific location, create a coordinate system at the location. Then right click on Solution and insert Probe -> Temperature. Then set location method to coordinate system and select the system you created. Evaluate the resultsnnnYou can use the selection filter to pick the node or elementn
      Add Tags
