Probelms with esel
    • John Miller
      I'm struggeling with the esel command. In the simulation I create surface elements at the external nodes of an workpiece within the /prep7, then I go back to the /solu. A single frame restart analysis:
      Time,i*dt
      solve
      save,file,db
      /prep7
      /GOPR
      /com,!------------------------------------------------------------------------
      /com,Start surf152
         esel,s,ename,,surf152            ! Element selection of surf152 elements
         cm,ELsurf152,elements         ! Create a component which includes surf152 elements
         edele,ELsurf152                    ! Deletion of former surf152 elements
         et,100,152
         keyopt,100,4,1
         keyopt,100,5,0
         keyopt,100,8,1
         cmsel,s,external,node
         esln,all
         type,100
         esurf
         esel,none
         esel,s,type,,100
         esel,stat
         esel,s,ename,,152
         esel,stat
         cm,surfElem152,elem
         esel,stat
         allsel,all
         outres,all
      save,file,db
      /com,Ende surf152
      /solu
        trnopt,full
        nropt,full
        thopt,full
      save,file,db
        antype,,restart
      /com, Start surf152
        nsel,none
        esel,none
        cm,surfElem152,elem
        esel,stat
        sfe,surfElem152,1,hflux,,hflux_test
      /com, Ende surf152
        allsel,all
        outres,all,all
      *enddo
      The solver output is :
      *** LOAD STEP     1   SUBSTEP     1  COMPLETED.    CUM ITER =      1
       *** TIME =  0.100000         TIME INC =  0.100000      NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  67.99       OSCILLATION LIMIT =  6.799
       *** ANSYS BINARY FILE STATISTICS
        BUFFER SIZE USED= 16384
              4.688 MB WRITTEN ON ELEMENT SAVED DATA FILE: file.esav
              3.812 MB WRITTEN ON ASSEMBLED MATRIX FILE: file.full
              5.500 MB WRITTEN ON RESULTS FILE: file.rth
       ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.db
        FOR POSSIBLE RESUME FROM THIS POINT
       FINISH SOLUTION PROCESSING
       ***** ROUTINE COMPLETED *****  CP =         1.250
       *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2021 R2          21.2     ***
       Ansys Mechanical Enterprise Academic Teaching
       00000000  VERSION=WINDOWS x64   22:10:36  MAR 24, 2023 CP=      1.250
       ConvRadSURF152Test--Thermisch-transient (B5)
                ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
       Start surf152
       SELECT       FOR ITEM=ENAM COMPONENT=
        IN RANGE       152 TO        152 STEP          1
             1280  ELEMENTS (OF       6720  DEFINED) SELECTED BY  ESEL  COMMAND.
       DEFINITION OF COMPONENT = ELSURF152  ENTITY=ELEM
       *** WARNING ***                         CP =       1.250   TIME= 22:10:36
       Assembly ELSURF152 is deleted.
       ELEMENT TYPE        100 IS SURF152      3-D THERMAL SURFACE
        KEYOPT( 1- 6)=        0      0      0        0      0      0
        KEYOPT( 7-12)=        0      0      0        0      0      0
        KEYOPT(13-18)=        0      0      0        0      0      0
       CURRENT NODAL DOF SET IS  TEMP
        THREE-DIMENSIONAL MODEL
        KEYOPT( 1- 6)=        0      0      0        1      0      0
        KEYOPT( 7-12)=        0      1      0        0      0      0
       SELECT      COMPONENT EXTERNAL
       SELECT      ALL ELEMENTS HAVING ANY NODE IN NODAL SET.
              138 ELEMENTS (OF       5440  DEFINED) SELECTED FROM
            225 SELECTED NODES BY  ESLN COMMAND.
       ELEMENT TYPE SET TO       100
       GENERATE ELEMENTS ON SURFACE DEFINED BY SELECTED NODES
        TYPE=      100  REAL=        1  MATERIAL=        1  ESYS=    0
       NUMBER OF ELEMENTS GENERATED=         12
       NONE SELECT  FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO       9100 STEP          1
                0  ELEMENTS (OF       5452  DEFINED) SELECTED BY ESEL  COMMAND.
       SELECT       FOR ITEM=TYPE COMPONENT=
        IN RANGE       100 TO        100 STEP          1
               12  ELEMENTS (OF       5452  DEFINED) SELECTED BY  ESEL  COMMAND.
       ****** STATUS OF ELEMENTS ******
       NUMBER OF SELECTED ELEMENTS=        12
       NUMBER OF DEFINED ELEMENTS=       5452
       MAXIMUM ELEMENT NUMBER=           9100
       DEFINITION OF COMPONENT = SURFELEM152  ENTITY=ELEM
       SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF LAST
         FOR ALL APPLICABLE ENTITIES
       Ende surf152
       ***** ROUTINE COMPLETED *****  CP =         1.328
       *****  ANSYS SOLUTION ROUTINE  *****
       PERFORM A FULL TRANSIENT ANALYSIS
        USING NEWMARK ALGORITHM
       USE THE FULL NEWTON-RAPHSON OPTION FOR  ALL DEGREES OF FREEDOM
         AND USE THE DEFAULT ADAPTIVE DESCENT OPTION
       Use Full Nonlinear Thermal Transient Solution
       PERFORM A TRANSIENT ANALYSIS
        RESTART PREVIOUSLY RUN ANALYSIS TO ADD ADDITIONAL LOAD STEPS
        RESTART WILL BE CONTINUED WITH EXISTING LOADSTEP
        RESTART WILL BE PERFORMED BASED ON:
         PREVIOUS LOADSTEP =      1 SUBSTEP =      1
       RESUME ANSYS DATA FROM FILE NAME=file.rdb
           DO NOT PLOT ANYTHING
       *** ANSYS GLOBAL STATUS ***
       TITLE = ConvRadSURF152Test--Thermisch-transient (B5)
       ANALYSIS TYPE =  TRANSIENT
       NUMBER OF ELEMENT TYPES =      5
            6720 ELEMENTS CURRENTLY SELECTED.  MAX ELEMENT NUMBER =        9088
           21662 NODES CURRENTLY SELECTED.     MAX NODE NUMBER =          21662
              17 COMPONENTS CURRENTLY DEFINED
       MAXIMUM LINEAR PROPERTY NUMBER        =       2
       MAXIMUM REAL CONSTANT SET NUMBER      =       4
       ACTIVE COORDINATE SYSTEM              =       0  (CARTESIAN)
       NUMBER OF SPECIFIED CONSTRAINTS       =   15738
       NUMBER OF SPECIFIED SURFACE LOADS     =    2560
       CURRENT LOAD CASE =      0 OF      0
       LOAD SET   =       1
       SUBSTEP    =       1
       TIME/FREQ  =   0.10000
       INITIAL JOBNAME = file
       CURRENT JOBNAME = file
       RESTART PROCEDURE RE-BUILDS BOUNDARY CONDITIONS
       AND LOADING INFO UPTO THE CURRENT LOADSTEP
       READ ANSYS LOADS DATA FROM FILE= file.ldhi
       DELETE SOLID MODEL BOUNDARY CONDITIONS
       NUMBER OF NODAL CONSTRAINTS DELETED                       =     15738
       NUMBER OF ELEMENT CONVECTIONS/HEAT FLUXES DELETED         =      1280
       *** NOTE ***                            CP =       1.625   TIME= 22:10:37
       The number of results set on the restart command is the last set on the
       RTH file.  No updating for the RTH file is required.
        Start surf152
       NONE SELECT  FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO      21662 STEP          1
                0  NODES (OF      21662  DEFINED) SELECTED BY NSEL  COMMAND.
        IN RANGE         1 TO       9088 STEP          1
       NUMBER OF SELECTED ELEMENTS=         0
       NUMBER OF DEFINED ELEMENTS=       6720
       MAXIMUM ELEMENT NUMBER=           9088
       SPECIFIED SURFACE LOAD HFLU FOR ALL PICKED ELEMENTS  LKEY = 1
           VALUES =     500.00         500.00         500.00         500.00
        Ende surf152
      The output shows 12 surf152 elements are created in /prep7, but I can't select them with esel in the /solu after restart.
       I don't know why
      With best regards
      John Miller
    • Mike Rife
      Hi John
      In the restart you accidentally redefined the component surfElem152 with no elements selected.  So it is an empty component.  I think that is a mistake...as is selecting none for nodes/elements prior.  Just issue the SFE command with the component name...no need for selecting some subset.  MIke
      • John Miller
        Hi Mike,
        thanks for the help.
        I change the code regarding your advice, but unfortunately, something is still wrong.
        Time,….
        solve
        save,file,db
        /prep7
        /GOPR
        /com,!---------------------------------------------------------------------------------------------------------------------!
        /com,Start creation of surf152 for convection and radiation
           esel,s,ename,,152             ! Element selection of surf152 elements
           et,100,152
           keyopt,100,4,1
           keyopt,100,5,0
           keyopt,100,8,1
           esln,all
           type,100
           esurf
           esel,none
           esel,s,type,,100
           esel,stat
           esel,s,ename,,152
           esel,stat
           cm,surfElem152,elem
           esel,stat
           allsel,all
           outres,all
        save,file,db
        /com,End creation of surf152 for convection and radiation
        /solu
          trnopt,full
          nropt,full
          thopt,full
        save,file,db
          antype,,restart
        /com, Start surf152 selection for thermal load
        !  cm,surfElem152,elem
          nsel,stat
          esel,stat
          sfe,all,1,conv,2,Tbulk
        /com, End surf152 selection for thermal load
          allsel,all
          outres,all,all
        *enddo
        The solver output is indicating that 6720 Elements are selected, but in the /prep7 I created 12 surface elements.
         *** WARNING ***                         CP =       1.281   TIME= 09:23:28
         ***** ROUTINE COMPLETED *****  CP =         1.375
         LOAD SET   =       1
         SUBSTEP    =       1
         TIME/FREQ  =   0.10000
         *** NOTE ***                            CP =       1.672   TIME= 09:23:28
         ****** STATUS OF NODES ******
         NUMBER OF SELECTED NODES=     21662
         NUMBER OF DEFINED NODES=      21662
         MAXIMUM NODE NUMBER=          21662
         NUMBER OF SELECTED ELEMENTS=      6720
         SPECIFIED SURFACE LOAD CONV FOR ALL SELECTED ELEMENTS  LKEY = 1   KVAL = 2
             VALUES =     25.000         25.000         25.000         25.000
         *** WARNING ***                         CP =       1.672   TIME= 09:23:28
         Some of the defined and selected elements did not require convections.
         Use the SFELIST,ALL,CONV command to view a list of elements that did
         have convections stored.
        I don’t get it, seems it’s not possible to pick the surface elements created in /prep7 in /solu .
        With best regards
        John
    • Mike Rife
      John
      Check the output - the restart database is being resumed (file.rdb) after you resumed the saved database.  The restart db does not contain the changes you made to the FEM.
      What is the point of redoing the surface effect elements in this model?  Perhaps we need to step back and assess the overall workflow.
      Mike
      • John Miller
        Hello Mike,
        I need the surface elements for an AM simulation. During the extrusion process, the elements are partially external and become after they are covered with the new layer internal. As you can see in the pictures
        It’s not possible to apply radiation with GUI, because the external surface will match the finished workpiece shape after the building is done. Elements are external and become internal and so on. Application of convection via external nodes is easy, but radiation is the problem.
        I thought surface elements could be the solution to this issue. Unfortunately, multi-frame restart is not possible in ansys transient thermal and a coupled thermal structural simulation is too time-consuming.
        If it’s not possible to select the surf152 elements in /solu after creation in /prep7 and a single frame restart, the whole simulation is impossible.
        With best regards
        John
