Proble in 3D
    • Supratap
      I am trying to simulate a LSRM in 3D. But the inductance plot which I am getting is very arbitrary. It has spikes and its value is decreasing. It should be periodic. I have tested the 2d sim it is fine. Please suggest what can be done.
    • Karthik R
      Administrator
      Hello, nWhich team are you using?nThanks.nKarthikn
    • Supratap
      What do you mean by team?.
    • Karthik R
      Administrator
      So sorry - I meant which 'tool' are you using? Is this Ansys Maxwell?nThanks.n
    • Supratap
      yes!nn
    • Navya C
      Hi,nSince you got the results as expected in 2D you should be getting appropriate results in 3D as well. nIt is difficult to pin point the issue with out knowing how your model set up is.nCan you provide us with the addition information onnHow is your motion setup in 3D compared to 2D.nExcitation comparison (If you there are any inputs related to end winding inductance and resistances check if the units are correct)nSolution setup comparison.nAlso provide us with any additional screenshots of your model for better understanding.nLSRM stands for Linear switched reluctance motor in your case. Is it correct?nnRegards,nNavyan
Viewing 5 reply threads
