August 24, 2018 at 7:57 am
ceHumaNait
SubscriberDear all,
Recently, I am trying to simulate a orthotropic plane in ANSYS using SHELL181. The APDL input is as follows:
finish
/clear
/prep7
*afun,rad
et,1,shell181
sectype,1,gens,,bandanyuan,
sspa,420626,126188,,4.24713e8,,,
sspd,43.6662,13.0999,,48446.7,,30.6256,
sspe,,8.15102e7,
k,1,0,0,0
k,2,2.31,0,0
l,1,2
cm,tra,line
k,3,0,0,-12.164
l,1,3
adrag,tra,,,,,,2
allsel,all
mshape,0
mshkey,1
aatt,1,1,1,,1
amesh,all
!D11
allsel,all
lsel,s,loc,x,0
dl,all,,ux
dl,all,,uy
dl,all,,uz
dl,all,,rotx
dl,all,,roty
dl,all,,rotz
allsel,all
allsel,all
lsel,s,loc,x,2.31
dl,all,,ux
dl,all,,uy
dl,all,,uz
dl,all,,rotx
dl,all,,roty
dl,all,,rotz,1/50
allsel,all
When I ran the code, I got the following error messages:
*** NOTE *** CP = 10.374 TIME= 15:46:05
Predictor is ON by default for structural elements with rotational
degrees of freedom. Use the PRED,OFF command to turn the predictor
OFF if it adversely affects the convergence.
*** ERROR *** CP = 10.374 TIME= 15:46:05
Membrane stiffness of Element 10 (integration point 1) at temperature 0
is not positive definite.
Shear stiffness of Element 10 (integration point 1) at temperature 0 is
Membrane stiffness of Element 12 (integration point 1) at temperature 0
*** ERROR *** CP = 10.390 TIME= 15:46:05
Shear stiffness of Element 12 (integration point 1) at temperature 0 is
It seems that some material stiffness was not well defined. Can anyone give some suggestions about how to solve this problem?
Thank you very much!
Kind regards,
ceHumaNait
August 24, 2018 at 1:12 pm
Rohith Patchigolla
Ansys EmployeeHello ceHumaNait,
Can you also include the material property definition. I don't see it in your script.
Best regards,
Rohith
August 24, 2018 at 7:23 pm
sk_cheah
SubscriberLooks like your stiffness matrix is not positive definite.
Kind Regards,
Jason -
August 27, 2018 at 10:19 am
ceHumaNait
SubscriberHello rgpatchi,
In our simulation, we intended to specify a preintegrated membrane stiffness for shell sections instead of specifying isotropic linear elastic material properties. We first calculate the stiffness properties of the shell and then apply them using the "SSPA" "SSPD" and "SSPE" commands, which is corresponding to command lines:
sspe,,8.15102e7,
However, the commands do not work well. Do we make any mistakes using these commands?
Best regards,
ceHumaNait
August 27, 2018 at 10:22 am
ceHumaNait
SubscriberHello Jason,
Thank you for your reply. Do you have some suggestions to make the stiffness matrix positive definite? As this is the first time we use preintegrated stiffness for shell elements, we find it difficult to solve this problem.
Best regards,
ceHumaNait
2086
1317
1108
459
