October 6, 2018 at 9:31 pm
rubenruizgonzal
SubscriberHello,
After installing ANSYS 19.2, I try to open the Workbench but it doesn't let me enter it, it gives me the next problem:
"Unexpected error: The folllowing required addins could not be loaded: Ans.SceneGraphChartAddIn. The software will exit".
Looking forward for your answer.
October 8, 2018 at 11:02 am
ANSYS_MMadore
Ansys EmployeeHello,
This could be an issue with Windows user account contains some special characters or non-English language alphabets. For a quick test, try creating a new/simple Windows user account that contains only English letters and/or numbers, such as abc, a123, etc. , and see if that fixes the issue.
Thank you,
Matt -
October 8, 2018 at 3:24 pm
rubenruizgonzal
SubscriberHello,
I have tried to do that but it gives me the same error.
Thank you for your attention, looking forward for your answer.
October 8, 2018 at 5:37 pm
tsiriaks
Ansys EmployeeHi rubenruizgonzal,
Please post the screenshot of the output of 'set' command (without quote) from the CMD Prompt.
Thank you,
Win
October 8, 2018 at 5:58 pm
October 8, 2018 at 7:19 pm
tsiriaks
Ansys EmployeeCan you login to the new account that you created per Matt's suggestion above, then post the output of the set command ?
Thank you,
Win
April 17, 2019 at 8:02 am
ellani
Subscriberhow to stop the simulation of Ansys 2019 R1 during running of the case? i have to wait for the ansys to stop run for few hour even after i got the result that i want from cd, cl and st graph. -
April 17, 2019 at 3:03 pm
JakeC
Ansys EmployeeHi ellani,
Please create a new topic/thread for this question and specify which products you are using, and the steps you are taking to run a job.
Also please specify if you are running the job locally or sending to a cluster, and if this happens with all projects or just this one.
Thank you,
Jake
- Workbench error
- Workbench not opening
- License Error
2726
2148
1359
1150
462
