3D Design
3D Design
Problem at Ansys design modeler ‘trim’
    • Noused
      well... I use modify command 'trim',  and I think , when i use the 'trim', The portion of the edge up to its intersection with other edge, axis line, or point will be removed. but why this situation happened??
      (sry for my poor english writing skills.)
    • Keyur Kanade
      It could be only graphical representation.
      Please go ahead and create 3D bodies from this sketch and check if it gives any problem.
    • Keyur Kanade
      If you go to Tools - Options - DM - Graphics - Facet Quality and change this to 10, you will see improvement in display.
      So its only display issue. You can go ahead with your model.
      If this answers your question, please mark this as 'Is Solution' to help others on forum.
    • Noused
      Thanks.
Viewing 3 reply threads
