Discovery Import
Discovery Import
Problem between Spaceclaim and Keyshot
    • ybiran
      Good morning, sir,
      A client discovery Spaceclaim has a problem with spaceclaim is Keyshot!
      He models a volume in Spaceclaim, then he uses the bi-directional plug in to transmit the geometry in Keyshot.
      As you can contact him on the attached image, Keyshot opens but you can't see the geometry. If you go back to Spaceclaim, it crashes automatically...
      We tried to uninstall discovery and Keyshot to reinstall as administrator but the problem persists.
      Do you have a solution to solve this problem?
      Best regards
    • Brian Bueno
      NOVACAD
      Try updating the graphics drivers on the PC.  Also make sure antivirus or Windows Defender are not interfering both at the time of installation and when launching KeyShot.  In some cases these may prevent critical items from being installed, or prevent SpaceClaim from properly launching  and linking with KeyShot.
      • omajo
        Brian Bueno
        hello brian,
        I'm coming back to you with my problem because I'm more accurate.
        my customer manages to make appear the 3d from spaceclaim for the files which has already realized. on the other hand it does not manage to make appear the 3d realized in spaceclaim, in keyshot. Even by applying a texture to the 3d
        best regards
      • omajo
        Brian Bueno
        hello brian,
        it's the scan of an error message that may be related to this keyshot problem : when you go to the spaceclaim options, in the add-ons
        best regards
    • ybiran
      Hello Brian,
      I took the hand on the client PC, its graphic card was up to date!
      But we disabled the firewall and it works again!
      Thanks for the advice.
      See you soon.
