November 14, 2020 at 7:09 am
saggukamal538
Subscriberi have successfully installed ansys 2020R2 . but when i go to start workbench with administrater permission it shows an unexpected error .
please help
November 14, 2020 at 7:10 amsaggukamal538
Subscriberplease help immidiatly nDecember 2, 2020 at 3:39 pmANSYS_MMadore
Ansys EmployeeCan you please share the text from the referenced file in the error message?.nDecember 2, 2020 at 3:39 pmANSYS_MMadore
Ansys EmployeeAlso, does this happen from simply trying to click on Workbench 2020 R2 in your Windows Start menu?nViewing 3 reply threads- The topic ‘problem during starting of ansys workbench’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Results Probe in ANSYS Workbench
- Unable to delete system in Ansys Workbench
8808
4658
3153
1680
1470
