September 14, 2018 at 10:18 pm
keishlaortiz
SubscriberHello,
I'm simulating the cardiovascular system on ANSYS, where my goal is to inject nanoparticles at certain locations in the cardiovascular system to see if it reaches the target area(s). I want to get the amount of nanoparticles trapped or escaped in certain boundaries. So far, I could get that information from the .dpm files generated for each inlet, outlet and arteries wall from Report/Discrete-Phase/Sample from the GUI since I can select the desired boundaries and injections. However, I would like to run multiple simulations from the command prompt using journal files but when I ran the command from journal: "/report/dpm-sample injection_name () "boundary1" "boundary2" ... "boundaryn" () () no yes" it's giving me an error indicating that the injection name is not a valid command. My question is what's the correct command to get the dpm-sample reports choosing the desired injections and boundaries?
My journal file looks like this:
/file/read-case-data sce1_v8.cas
/solve/initialize/hyb-initialization
/file/auto-save/data-frequency 1
/report/dpm-sample v8 () "wall-artery" "inlet1" "outlet1" "outlet2" "outlet3" "outlet4" "outlet5" "outlet6" "outlet7" "outlet8" "outlet9" "outlet10" "outlet11" "outlet12" "outlet13" "outlet14" "outlet15" "outlet16" "outlet17" "outlet18" "outlet19" "outlet20" "outlet21" "outlet22" "outlet23" () () no yes
exit
v8 is the injection name, so far the previous commands work perfectly, the error is with the repot dpm sample command. Any help would be really appreciated. Thanks.
September 17, 2018 at 9:42 am
Ansys EmployeeWhat happens if you manually type in the command, ie type
/report/dpm-sample
v8
list of surfaces
etc
Trouble shooting TUI commands is best done this way, and on the model you're running as the commands can change slightly depending on models.
As an aside your journal will read the case, initialise, report DPM tracks and then close: it's not going to do anything else.
October 22, 2018 at 6:14 pm
keishlaortiz
SubscriberHi.
Thanks for the reply, however, that's how I got the TUI command (by troubleshooting them in ANSYS Fluent console) to write the journal file and still didn't work. However, I changed something in my model that will not require to get the results in the .dpm files.
December 3, 2019 at 11:56 pm
Geckoo
SubscriberI would also like to do dpm-sampling in batch mode. I do not receive an error message using
/solve/initialize/initialize-flow
/report/dpm-sample/inj130bar () outlet int_fluid () plane-x76 plane-x46 () yes no
/solve/iterate 199
However, I receive lots of plane-x76.dpm.n files. How do I get one merged report file?
December 4, 2019 at 9:41 am
Ansys EmployeeIf it works you should get one file, a .dpm.n extension suggests that something didn't quite work. What's in the file?
December 6, 2019 at 11:05 pm
Geckoo
SubscriberMany of the files are empty and a few contain some thousand lines of data in the form
-4.60E-02
5.41E-03
7.99E-03
-2.08E+02
1.12E-01
-2.82E+00
3.65E-06
2.99E+02
1.82E-12
2.55E-14
7.12E+01
2.80E-04
2.80E-04
inj130bar:181)
That is the typical form I guess. I merged all the files in the windows cmd using
FOR %f IN (plane-x46*) DO type %f >> ..merge.txt & echo. >> ..merge.txt
2508
2064
1277
1088
456
