problem in combin39
    • oumaimalahmar.ol
      hello
      I model a 2d plate with two pegs (I presented them by 2 nodes where I blocked all translations).
      the plate is hooked on the ground (concrete) so we wanted to make a modeling with springs, then the plate is in shell on which hangs springs modeling the concrete contact, then I used combin39 (according to z) for compression (I want my peg to work only in compression) and for shear I used combin 14 (according to x and y)
      my problem is that my springs only work in tension, see the photo of the results:
      there are the keyopt that I used :
      Thank you
    • oumaimalahmar.ol
      @peteroznewman can you help me plz
