Discovery Import
Discovery Import
Problem in drawing in spaceclaim
    • ybiran
      I'm bringing up an information because I have a client who has recurring problems with the layout. He makes large assemblies of several thousand parts and they regularly have severe slowdown problems.
      Also, sometimes the lines are not displayed in all the views of the drawing.
      And finally, recently he had a drawing with a sectional view and dimensions, everything was working fine and he needed to make a revision to the model but the sectional view had disappeared without any intervention on their part and the dimensions were also gone!
      Here are two pictures of before and after the problem.
      Best regards
      Yohann
    • Naresh Patre
      Hello NOVACAD
      I don't recall seeing such issue before. Let me check with the team and will get back to you.
    • jsuneby
      NOVACAD This is a strange issue. In order to fully understand the problem, we would need to see the files and attempt to reproduce the issue. Are these files shareable? If so, let me know, and I can send you a secure transfer file request.
