November 24, 2019 at 6:46 pm
Abdessamad
SubscriberHello all,
I have a problem when I import the geometry in DM it's turn to 2D surfaces (Shell) but in the CAD software i created them as solid parts I don't know if there is a special way to avoid this , I try with 2 differents assembly the STEP and Catpart files, I got the same result.
Thanks in advance.
November 24, 2019 at 9:17 pm
SubscriberYou can sew together the surfaces in DM to create a Solid.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5162
3253
2443
