September 15, 2018 at 8:49 am
yuka
SubscriberMy pc has following configuation.
C: 21GB
H: 583GB
RAM 32GB
Is it possible to set the installation destination to C drive and save the working file on the external hard drive?
September 15, 2018 at 6:18 pm
SubscriberYou can install the program on the C: drive and have the working files on the H: drive.
September 17, 2018 at 9:38 am
Ansys EmployeeIt's possible but I'd try and save files to the local drives when working and then copy across later. It's not much of an issue with the pre-processing files but when you start adding parallel solvers into the mix there's a risk of data packet corruption.
21GB is an odd size for a hard drive, is there a second partition?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2666
2120
1349
1134
461
