Problem in patching
    • GuptaRajesh2304
      Hello everyone.
      I having problem in patching of two regions in a domain in fluent. Please guide me to solve this problem.
      What problem are you having? You will need to initialise the flow first, then patching is usually pretty easy.
    • GuptaRajesh2304
      hello sir,
      after initialization, i have to patch two regons but it is showing only one patched region in contours.
      Then you will need to the patch on the other region. We often use patch 2-3 times to change phases, add energy somewhere and the like.
Viewing 3 reply threads
