Problem in plotting p theta diagram,when doing combustion analysis
    • akhilskuttattu
      I am working on the project of Modelling of Combustion Process of Internal Combustion Diesel Engine Using Ansys ICE Fluent, in Which I am facing problem to obtain the Desired Result.
      My Objective: To plot Graph between Crank angle and Cylinder Pressure of IC Engine
      Problem: The output Report which is given by the Ansys ICE Fluent after simulation does not have the correct plot,its a plot between flow time and time step
Viewing 0 reply threads
