Problem in Running Simulation using Parameter Set in ANSYS2020R2
    • parth144
      Hello, I'm trying to run one simulation in which rotation of the body in the computational domain is defined as a parameter using ANSYS2020R2. But When I try to define the second angle of attack, I'm getting an error as you can see in the image. Not sure, Why It's not working? Can you all help me with this to solve it?
      Thank you in advance!
    • DrAmine
      It already fails in the geometry cell.
      I saw this kind of messages in the past due to having old preferences on the machine but they can have some other roots. For that reason start debugging it:
      Please start by removing / resetting your preferences (rename or remove the folders ~/.ansys ~/.mw /.config/Ansys and /tmp/Mw_${user}).
    • parth144
      Thanks for the reply!
      I followed your direction but I'm still getting the same error as you can see in the following image. Any other suggestions to fix this problem?
      Can you open the geometry cell and see how the 10 degree geometry looks? Depending on how you've set the dimensions relative to each other the sketch my be gibberish at 10 degrees.
    • DrAmine
      Open the cell and do the change directly: will the geometry fail?
Viewing 4 reply threads
