Problem In Specific heat UDF in eulerian multiphase flow
    • cmiucbs
      Hi I'm having problem writing a temperature dependent specific heat macro for my eulerian two phase boiling flow simulation.
      I want to get the primary phase temperature from the cell and use it in the code but having problem to do so; I already did the other properties like density using DEFINE PROPERTY macro but since specific heat is kinda different I'm getting odd answers.
      So here is my code and I narrow the problem down to the bold words:
      DEFINE_SPECIFIC_HEAT(specficheat,T, Tref, h, yi)
      real cpf;
      Domain *mixture_domain = Get_Domain(1);
      Thread *mixture_thread = Lookup_Thread(mixture_domain,8);
      Thread *t_wa = THREAD_SUB_THREAD(mixture_thread,0);
      Thread *t_va = THREAD_SUB_THREAD(mixture_thread,1);
      cell_t c;
      real Tw = C_T(c,t_wa);
      cpf=(((5067-4494)/70)*(Tw-473.15)+4494);
      *h = cpf*(T-Tref);
      return cpf;
      Using the above code lead to wrong values for cp; what can i do to calculate the cp only with my primary phase temp? Can anybody help me on this?
    • Surya Deb
      The thread allocations look fine to me.
      I would recommend you to print out the primary phase temperature inside the UDF and then compare that to the Fluent GUI to check if everything is consistent or not.
      I would also suggest you to use a simpler Cp value (say a linear function or even a constant) for testing if the code is doing what its supposed to do.
      Regards SD
