August 20, 2019 at 11:34 pm
pratikroy94
One way coupling of Maxwell and Steady State Thermal is working well in our ANSYS Workbench. We have imported motor losses from the Maxwell to Steady State Thermal successfully for electric motor and also got the temperature distribution map of electric motors in Steady State Thermal from the imported motor losses.
But we couldn’t able to export the temperature results to Maxwell to resolve the electromagnetic simulation of electric motor. We have checked all the options needed to get temperature dependency option enabled into Maxwell such as enabling thermal modifier for copper and putting the temperature-dependent equation in the bulk conductivity section, checking temperature dependency and enable feedback option in the object temperature section.
Although everything looks fine, the imported load in Steady State Thermal doesn’t show any option for exporting the temperature results after solve. According to ANSYS tutorial file, there should be an export definition in imported load’s detail tree where export after solve option needs to be selected as ‘YES’. But in our Steady State Thermal, there is only limited information (attached picture). Can anyone please help us with this problem? What should be done to solve this issue?
September 20, 2019 at 12:44 am
carpekev
SubscriberHi pratikroy94,
Were you able to achieve the temperature feedback from Thermal to Maxwell? If not, try using Workbench's Feedback Iterator to get it to work. Be sure to change the "Max Iterations" from the default 100 to something small, but greater than 1, otherwise the feedback iterator will solve the entire system over and over until the target temperature convergence is reached, which, if not properly defined, could be forever. So just use a small number to see if it's working. Once the feedback iterator is set up, just click "Update Project" at the top.
May 4, 2020 at 6:33 pm
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2524
2066
1279
1096
457
