July 24, 2019 at 5:44 am
July 24, 2019 at 4:50 pm
tsiriaks
Ansys EmployeeIf you go to that directory, do you see Ans.Simulation.Core.dll ?
Do you have any .err file under C:Program FilesANYS Inc folder ?
Can you try installing newer version ?
Thanks,
Win
July 24, 2019 at 5:06 pm
Sushanth27
SubscriberI can see Ans.Simulation.Core.dll file in that directory and i found i file named err.png, err.png2.
When i installed 19.1 version i found issue of loading mechanical handlers. I have re-installled 18.1 and 19.1 several times but the problem didn't get solved
July 24, 2019 at 5:56 pm
tsiriaks
Ansys EmployeeRemove the C:Program FilesANYS Inc folder, then reinstall new version on it. Make sure you run the installation with 'run as administrator'
After the installation is done, check if you have any .err file in this C:Program FilesANYS Inc folder (do not search for its sub folders, just the file in ANSYS Inc folder). If you have .err file, post the content of it here
Thanks,
Win
July 25, 2019 at 5:54 am
Sushanth27
SubscriberSir i have tried this, by deleting Ansys.inc file and installing other version but i am facing same problem
July 25, 2019 at 4:45 pm
tsiriaks
Ansys Employeeopen CMD Prompt, then issue the following command
set
then post the screenshot of it here
Also, post the screenshot of your C:Program FilesANYS Inc folder
July 26, 2019 at 9:35 am
July 26, 2019 at 3:28 pm
tsiriaks
Ansys EmployeeIt seems you refer to ANSYS 2019 R2 (19.4) as 19.1
Do you have any .err file in C:Program FilesANSYS IncANSYS Student folder ? If so, please post the entire content of it here.
Try 'unset' (delete) your ANSYSLIC_DIR environment variable.
Also, open CMD Prompt, then issue the following command
move %appdata%ansys %appdata%ansys.bak
July 27, 2019 at 6:18 am
July 27, 2019 at 6:27 am
Sushanth27
Subscribersir the 19.1 version is working now, thank you sir.
now if i re-install 18.1 version will it work?
July 29, 2019 at 3:58 pm
tsiriaks
Ansys EmployeeYour environment variables and your error message show 19.4 , not 19.1 .
Also, if you look at the folder under C:Program FilesANSYS IncANSYS Student , you are going to see v194 , not v191.
It depends on what was the issue for your 18.1. You can try it and let us know.
July 31, 2019 at 5:28 am
Sushanth27
Subscriberok sir
December 22, 2020 at 7:21 am
akky112
SubscriberGo to appdata folder and delete ansys folder from local and roaming folder. Your issue will be resolved. n
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2684
2124
1349
1136
461
