November 2, 2023 at 10:13 am
Davide Monopoli
SubscriberHi, when I use my own material data with proper definition in material database it happens that when I launch a simulation braodband in varFDTD 2.5 it gives me divergence... so that I can't simulate the behaviour of the dispersion on my field.
It works properly the narrowband option with same conditions..I tried to change all the parameters about mesh/boundaries/ fitting but nothing.
Any suggestions?
Thanks
November 2, 2023 at 9:35 pm
Devika
Ansys EmployeeHi,
Can you share the screenshot of the error message ?
You can also get in depth information about diverging simulation in the following link:
Troubleshooting diverging simulations in FDTD – Ansys Optics
Thanks and regards
Devika
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8778
4658
3151
1678
1460
