January 12, 2023 at 8:29 am
Colin Bannister
SubscriberI am having problems using later versions of cfx5pre on a remote Linux system. I am using x2go to connect to teh system, which runs on Centos 7.9.
Using ANSYS v190, cfx5pre launches fine, with no errors. On all other versions (v201,v202,v211,v221,v222) it gives errors. On terminal I see:
cczcb@vis001(Augusta) ~]$ vglrun /software/ansys_inc/v222/CFX/bin/cfx5pre &
[1] 19129
[cczcb@vis001(Augusta) ~]$ Use of uninitialized value $comps[1] in join or string at /software/ansys_inc/v222/CFX/bin//perllib/CFX5/PathManip.pm line 263.
/software/ansys_inc/v222/CFX/bin/linux-amd64/PreGui_ogl.exe: /software/ansys_inc/v222/tp/qt/5.9.6/linx64/lib/libjpeg.so.62: no version information available (required by /software/ansys_inc/v222/tp/qt/5.9.6/linx64/lib/libQt5WebEngineCore.so.5)The splash screen opens, with an error as in the attached screenshot
If I click 'OK' I get a 'Fatal Error' pop-up, and have to abort the session.
If anyone has any ideas what might be happening, I'd be very grateful to hear.
thanks,
Colin
January 19, 2023 at 4:15 pm
George Karnos
Ansys EmployeeHello Colin,
Check that the Required Linux libraries are installed for the 202* versions.
Chapter 2 of the Linux installation Guide.
January 19, 2023 at 4:26 pm
Colin Bannister
SubscriberThanks George - I've found that chapter. I have tried a different installation method on the same system, and am now able to launch cfx5pre. I will try and work out why these are behaving differently!
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
