Problem of connecting CIRCU94 element to the defined nodes by using E command
    • Mueller
       I am trying to repeat an example analyses of a piezoelectric circuit in  Workbench (https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_cou/Hlp_G_COU_N4_6.html).
      I have defined piezo element properties of the same piezoelectric cube and top bottom electrodes. If I apply voltage, a simulation shows correct values. However, in the next step of adding CIRCU94 element by command lines I get an error:
      Element 1729 does not have all of its required nodes defined.  The E  command is aborted.
      The E command cannot store element 1729, possibly because one or more nodes is not defined.
      Another issue is a command " *get,Cs,node,n_top,rf,chrg ", is it possible to read a charge value in Workbench without command line?
      Thanks in advance.
      Best
Viewing 0 reply threads
