March 21, 2023 at 3:15 am
Ansys_SC OXTI
Hi, my discovery & space claims are having issue after reformatted my OS lately. First, I installed 2023R1. and it doesn't work. Then followed by reinstall the software to 2022R2, until 2022R1. It is still having the same issues.
Please do advice what should i do to solve the issues.
Thanks.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
March 21, 2023 at 6:57 am
Atharv Joshi
Forum ModeratorHi Ansys_SC OXTI ,
Please try downloading the patch January 2023 Subscription Licensing Issue - Knowledge Base - Ansys Discovery Forum and let me know if this resolves the issue.
If that doesn't work try disabling Intel graphics on the machine and see if that helps. Also please try installing the latest redistributable. You can try installing the appropriate one from here: Latest supported Visual C++ Redistributable downloads | Microsoft Docs
Please try installing the VC_redist.x64.exe and vc_redist.x86.exe for Visual Studio 2015, 2017, 2019 and 2022 package. If you already have 2015 installed, you may need to uninstall before installing this downloaded version.
Thanks and Regards.
March 22, 2023 at 2:27 am
March 22, 2023 at 2:55 am
Atharv Joshi
Forum ModeratorHello Ansys_SC OXTI ,
Can you please try activating the license again? I don't see any current activations.
Thanks and Regards
March 22, 2023 at 3:03 am
March 22, 2023 at 3:38 am
Atharv Joshi
Can you try launching it as administrator and see if that helps.
If that doesn't help, try activating the licenses using the command window and then try launching the application?
Please refer Discovery Subscription license - Command line options for instructions on activating licenses through command line.
Please check if you are using the latest installer Discovery Downloads - Knowledge Base - Ansys Discovery Forum
Also, make sure Firewalls/antivirus are not blocking SpaceClaim from running (temporarily turn off firewalls and antivirus).
Let me know if this resolves the issue for you.
Thanks and Regards
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
