problem on apply a follower load
    • freud farid
      my problem is Large defection of a curved cantilever beam under nonconservative tangential end load
      the load R=2400 N
      (see figure ) , i use a hyperelastic material so i model my beam as solid and i use solid186 element because beam188 element not support a hyperelasticity
      i try to apply a follower load , so o find this extension from ansys
      https://catalog.ansys.com/product/5bb222520750d7e4d73293d5/follower-loads
      I followed all the steps mentioned in the pdf that came with it but it not work and not converge
      i create a remote point on the face of the free end of beam with new coordinate system and aplly the follower load
      the problem is that the load applied on the top edge of the beam and not on the face with y direction
      this is the result that ansys give
      but the real deformation of the beam  supposed to be like this
      this is my project , i need to fix the problem
      link
    • Ashish Kumar
      Forum Moderator
      Please see if the following link helps: How can one define a follower load in Mechanical? - Ansys Knowledge
      Did you try changing the coordinate system to desired orientation?
      Ashish Khemka
      • freud farid
        i try it and unfortunately not work
    • Alessandro Agostinelli
      I'm having the same problem. I have applied a follower load on my model but the stress/deformation results are extremely low (10^-13). How can i fix that?
