Problem on ship trim and draft simulation using Fluent
    • GabrielL
      Hi all,
      I'm now attempting to create a 3D simulation on the trim and draft behavior of a ship hull under both flat and wavy sea conditions using ANSYS Fluent 19.2 Academic. I have created a large rectangular geometry consisting of four bodies (i.e. flow domains) connected together, the top two being the atmosphere and the bottom two being the water zone. The ship hull (i.e. a cavity in the geometry) is drawn interfacing between the middle two bodies. The reason that I do so is to allow coarser mesh to be done on the top and bottom bodies, while denser and refined mesh can be done in the middle two bodies, thus capturing the water surface and ship movement in more detail. The sizes of the flow domain is much larger than the ship hull.
      I have then generated the mesh using body sizing and refinement around the ship hull. This was then imported to Fluent to carry out analysis using VOF Open Channel Flow model. I chose k-omega standard viscous model, and assigned dynamic mesh to the ship hull using UDF to regulate its movement to pitch and heave only (z-direction displacement and rotation around y-axis). I used smoothing and remeshing method, with a spring constant factor of 0.5. The centre of gravity of the ship hull was defined 70% along the ship hull, with zero centre of gravity velocity. The inlet, outlet, atmosphere (pressure-outlet), ship hull (wall) and location of free surface were defined accordingly. I used a time step of 0.01s. For simplicity I did not assign any wave boundary conditions and the inlet velocity was kept at 0m/s. I initialized using hybrid initialization and flat condition.
      After I run the calculation, I kept getting problematic results including reversed flow at outlet, as well as wild movements of the ship as it bounces up and down in a large magnitude, which eventually led to divergent error. I would have expected that the ship remains stationary and having a slight trim angle due to the hydrodynamic forces on the ship on the location of centre of gravity.
      Can anyone here please help with my problem? The settings should be mostly correct but there were still erroneous results!
      Thanks!
      Gabriel
    • Keyur Kanade
      From description set up looks ok.
      You will need to check your UDF to see why there are forces to get wild movements.
    • GabrielL
      Dear kkanade,
      Thank you very much for your help.
      This  is what I included in my UDF:
      #include "udf.h"
      DEFINE_SDOF_PROPERTIES(stage, prop, dt, time, dtime)
      prop[SDOF_MASS] = 7.257;
      prop[SDOF_IYY] = 0.6165;
      prop[SDOF_ZERO_TRANS_X] = TRUE;
      prop[SDOF_ZERO_TRANS_Y] = TRUE;
      prop[SDOF_ZERO_ROT_X] = TRUE;
      prop[SDOF_ZERO_ROT_Z] = TRUE;
      printf ("nstage: updated 6DOF properties");
      I have also been wondering should I define the ship hull as a solid domain in fluent instead of simply creating a cavity in the fluid domain. However the latter seems to be the case for most online tutorials.
      I have actually also found a similar fluent tutorial on "heave and pitch simulation of ship" but I could not find where to download the geometry and mesh file for that tutorial. Is there anywhere to download that specific file?
      Thanks!
    • Keyur Kanade
      Can you please insert image for you inlet conditions.
    • GabrielL
      I set the open channel wave BC to none and inlet velocity to 0. However the drag force (Cd) I got was fluctuating from 0 to 0.5 initially, then up to 5 or even 10 or few hundred before it says "negative cell volume detected".
    • Keyur Kanade
      Can you please try with shallow waves with first order wave theory. Please give details of wave height and wave length.
      Is there any interface between two volumes? I see in the mesh that the mesh suddenly grows to bigger size. You may want to use conformal mesh with fine mesh. Please insert image of cross section of mesh. Also once you patch the volume, please check contours of vof before running.
    • GabrielL
      I attempted to create conformal mesh but this would automatically remove the refinement setting around the ship hull, which consists of curved surfaces and requires mesh refinement.
      Yes, everytime before I run I check the contour of water phase after initialization. It looks normal.
      The jump in cell size is very big, I usually aim for a volume change of around a factor of 2.  Before remeshing,  turn off the ship motion and see how the waves behave. If that fails review the mesh and repeat. Once the VOF bit works turn the moving ship back on.
    • Keyur Kanade
      As Rob suggested, you have to work on your mesh first before you get into solver. Usually multiphase problems need a good mesh.
      You will have to reduce that size jump. Also check quality of the mesh before going to solver. The min orthogonal quality should be more than 0.1
    • GabrielL
      Thank you all for your help!
      I have attempted to reduce the size jump and make use of conformal mesh but I still get a min orthogonal quality of 0.016 and max skewness of 0.98383 which indicated poor mesh quality. What are the possible ways to further improve the mesh quality?
    • raul.raghav
      You can visualize the regions where your mesh has skewed elements and try to focus on those regions to improve your mesh.
    • Keyur Kanade
      please check the bad elements location. then take corrective action.
    • Kevinsandoval
      Hello gabriel, I'm trying to simulate something similar to what you're doing, analyze the draft of a ship in calm sea situation, but I have not managed to make this simulation, maybe I have problems of boundary conditions or problems in the dynamic mesh, you have SETUP or messaging to guide me, I ask you please, I have not been able to find more information about this in the network, if you have more bibliography of this I will also be grateful, waiting for your message. thank you.
    • GabrielL
      Dear all,
      Thank you very much for the kind assistance!
      I have now been able to simulate the movement of the ship, but not completely. The only problem now I'm facing is that the model only works when the mass of the ship is larger than around 10kg. Below that (as what I intend to simulate a 7kg ship hull), non-physical and intense up-down movement of the hull is observed until the solution diverges. However, the model works perfectly fine with realistic physical pitch and heave behavior under no wave and wavy conditions when the mass is increased to a suitable value.
      I thought this can be solved by reducing the under-relaxation factors or flow courant number to improve convergence. I also tried reducing the time-step to 10^-5s. I have also tried using k-omega SST or k-epsilon realizable viscous model. However, these didn't solve the issue. May also kindly advise the possible solutions?
      For the setup of my model, please refer to the topmost post.
      Thanks very much!
Viewing 13 reply threads
