Ansys Products
Ansys Products
Problem opening SpaceClaim using ANSYS 18.2
    • diegosdv
      When I open SpaceClaim in the steady-state thermal analysis system, it doesn't show the origin axis, it appears just a gray screen that I can't do anything on it. Please, give me some suggestions to solve this problem!
      Thanks!
    • sefacancakmak
      i got same problem using space claim Ansys 19. Please help.
    • diegosdv
      Are you also using a windows 7 version?
    • sefacancakmak
      Yes i am using windows 7 proffesional.
    • Edilson Rosa
      Hi everyone!
      I also had this problem when I installed version 18.2, I easily fixed that by the following settings:
      Click on: FILE > SpaceClaim Options > In Advanced > Graphics > Verify what kind of GPU are you using (by default after installation is selected DIRECT3D11). It worked when I chose DIRECT3D9.
      Hope this helps.
      Edilson Rosa
    • diegosdv
      Thank you Edilson!! It worked here, problem solved!!
    • lucasalves
      Thank you Edilson, it had happened with the ANSYS 19.1.
    • vidhan28
      I'm not having the Direct3D9 option...what should I do?
    • tsiriaks
      it does not have to be Direct3D9 , you can try other rendering mechanism.
    • thansiyapa_gmail_com
      It is showing...nDirect3D11nDisablednWARPnOpenGL...nSo what should i choose.... Can u suggestn
Viewing 9 reply threads
