September 26, 2018 at 6:16 am
Abhi
SubscriberI have designed a model in solid works which has hinges and a certain degree of freedom. But i am facing problem when i am trying to transfer the file to ansys workbench. It is takinf it as ahole entity . it doesnt consider the model separately all the parts. First i am changing the model from sldprt to parasolid .xt file . then tgransporting but stilll the model is frozen . please suggest me step by step.
this is from solid works here the hinges works properly.
this is when i transfer it to ansys . here no flaps are working no hinges are working. its completely frozen.
September 26, 2018 at 12:52 pm
Ansys EmployeeThe DesignModeler part looks to have retained the 4 distinct bodies. You may need to set a rotation (move) for each valve leaf, but otherwise it looks OK.
September 26, 2018 at 1:24 pm
Keyur Kanade
Ansys EmployeeI can see you are using R17.1. Can you please update to R19.1.
Are transferring file to DM or ANSYS Mechanical directly? Accordingly I will move this thread to particular category.
Can you please read file in DM or SpaceClaim and let us know.
Keyur
September 26, 2018 at 2:19 pm
SubscriberAbhi,
I understand you have a SolidWorks CAD model where the parts move because you created Mates in SW that allows you to drag components in the degree of freedom that the Mates have left free.
The ANSYS geometry editors (DesignModeler and SpaceClaim) don't have Mates so there is no capability to drag parts around the degree of freedom that you could do in SW. It's just not there in the geometry editor. That is what you mean by "Frozen", but that word has a different meaning in DesignModeler, which is that the body is not merged with prior bodies, so you also want the bodies to have that characteristic. You can rotate or translate bodies in 3D space in the editors, but there is no persistent axis for that movement like there is in SW.
However, ANSYS Structural (or Fluent) models can have parts that are on Revolute Joints that allow parts to rotate about an axis when driven by Boundary Conditions (like a Joint Displacement or Torque Load) or forces calculated during the solution. You can see the motion once the solution is computed while post-processing the results.
September 27, 2018 at 12:06 pm
Abhi
SubscriberSir
I can read it from DM but the file is frozen. it is taking it as a single entity.
September 28, 2018 at 10:47 am
Ansys EmployeePlease can you post the image that shows the frozen geometry? The DM image above shows it's imported as 4 separate bodies.
September 28, 2018 at 12:54 pm
FrankD
Ansys EmployeeThe 192 release of AIM has in it the Assembly mechanism functionality from SpaceClaim Engineer. This allows you to define an anchor part and connect other parts (components) that move as a function of other manual or dimension-driven component movements.
So, while these types of things are not translatable across CAD packages, you can easily re-create many of them in SpaceClaim, especially ones with a reasonable number of components.
F
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
