3D Design
3D Design
problem related to geometry of IC Engine
    • pullah08
      I want to simulate IC engine but an warning is popping up Image of Warning
      so can anyone tell me how to cope up with this problem?
      I'm guessing that you need to check the injection positions as you've missed the volume.
    • pullah08
      Thank rwoolhou for replying
      but I checked all the possible coordinates of the Injection point but nothing is happening and same error is displaying I also tried generating a point in volume then also it is displaying same error.
      Can you expand the "5 Parts, 5 bodies" entry in the tree and double check you've imported volumes and not surfaces.
    • pullah08
      Actually these 4 parts are imported as suface can you tell how to convert them in volume.
    • pullah08
      and also picture that you asked for
      That's it. You've only got surface bodies: there are no volumes in the system. In DesignModeler or SpaceClaim it's relatively easy: not sure in the IC tools.
    • pullah08
      Can you please tell me how to do it in space claim?
      Thank you in advance
      Here you go
         it's the Repair tools that'll do it.  Also look up Share Topology to connect the various bodies.
    • pullah08
      Thank you  rwoolhou
      now there is no warning popping up.
    • pullah08
      Now there is a new problem after decomposing in design modeler I am getting null bodies
      Thanks in advance
      Suppress all the operations and then unsuppress one by one. Once you know the problem operation you need to figure out why it's doing that.
    • pullah08
      Thanks rwoolhou
      I think the problem is in coordinate system.
      Can you tell me how to interchange axis or do I need to draw a new geometry?
    • pullah08
      Yeah the problem was of coordinate system
      Thank's rwoolhou for your help
Viewing 13 reply threads
