October 6, 2018 at 4:11 pm
Georgiro
SubscriberDo you have an idea how to do it working properly? I do a point when creating a line, it is fine, but when I want to finish or make a second point to create a line, I cannot to finish it, it just does not accept the point, it does not do anything at all. So if you have a idea to change it, it would be great. Thanks
October 6, 2018 at 4:27 pm
Georgiro
SubscriberI just basically am not able to create a line or anything where I have to click, it does not accept it! Thanks for your ideas!
October 6, 2018 at 4:38 pm
SubscriberAre you trying to create the line in DesignModeler or SpaceClaim?
October 6, 2018 at 4:54 pm
Georgiro
SubscriberIs tbere someone who could help me with this issue? Thanks
October 6, 2018 at 5:11 pm
SubscriberPlease answer the question I posted above.
October 6, 2018 at 5:49 pm
Georgiro
SubscriberBut now I made an attempt in Ansys 15.0.7 and I found out that I have the same problem and I am unable to create an object or line, just nothing. So I will need something basic, if you can help me. Thanks
October 6, 2018 at 5:52 pm
Georgiro
SubscriberHow can I know this, can you tell me? Thanks
October 6, 2018 at 5:54 pm
Georgiro
SubscriberI used to work with 15.0.7 and it worked, but now not at all. So what shall I do? Thanks
October 6, 2018 at 6:04 pm
SubscriberIf your machine when running 15.0 was pointed to a license server, then either the license server is down, or your machine is not able to communicate with the license server. There are troubleshooting diagnostic tests that can be done. ANSYS 15.0 only has one geometry editor and it is called DesignModeler.
In ANSYS 19.0 there are two Geometry editors. When you right click on a Geometry cell in the Workbench Project Schematic, you can see there are two choices. The default is SpaceClaim, but you may also choose DesignModeler.
However, you began asking about ANSYS 19.0. Did you download the free ANSYS Student software, where the license is built-in? Or are you using a Research license where the license resides on a license server?
Please answer these questions to get further help.
October 7, 2018 at 10:26 am
Georgiro
SubscriberThanks for your ideas, I will try to make it working with the license.
October 7, 2018 at 12:36 pm
SubscriberCheck that you can see an available license. Using the Windows Start Menu, All Programs, ANSYS 19.0, ANSYS Client Licensing, Client ANSLIC_ADMIN Utility 19.0
When that opens, View Status/Diagnostic Options, Display the License Status
hostname--rocl3503.jpg?width=690&upscale=false" alt="">
You should see a list that shows the type of licenses available. Your list might be different that mine. Below I show one of several lines.
Please reply with a screen snapshot of what you see.
October 7, 2018 at 4:32 pm
Georgiro
SubscriberSo it is absolutely true what have you said, so it is the license server issue. But I would like to do with it, but I do not know at all what to do, because it does not work for version 15.0.7 at all as well. So if you have an idea to do with it, just let me know. Thanks a lot.
October 7, 2018 at 4:52 pm
SubscriberGeorgiro, you didn't show the screen snapshot of the License Status. Do you know who manages that license server?
Do you want to get the full license working or do you want to use the limited Student license?
If you want to build a model with the limits of bodies<50, faces<300 and nodes or elements<32,000 then you can download the free ANSYS Student 19.1 installation using the DOWNLOAD FREE SOFTWARE button at the top of this page. It has a built-in license and you don't have to connect with your old license server. If you go this route, you must clean all the old ANSYS off your computer.
Let me know what direction you want to go.
Peter -
October 8, 2018 at 2:08 pm
Georgiro
SubscriberSo I have checked the installation of the system 15.0.7 and 19.0 and it has been done as a license server, so everything well, but it is not working at all and I do not know. If you have any idea to tell me, just let me know. Thanks
October 8, 2018 at 2:47 pm
Peter -
October 14, 2018 at 12:53 pm
Georgiro
SubscriberDesign Modeller
October 14, 2018 at 1:01 pm
Georgiro
SubscriberThe absolutely serious problem is again to skatch a new model, because I change the dimensions, it change it, but it does not change the dimensions on the drawing - it does not change its lengths, etc. So it is not clear to me what to do with the drawing at all! Thanks The version is up to date. i. e. Ansys 19.2. Thanks
October 14, 2018 at 1:52 pm
Sandeep Medikonda
Ansys EmployeeGeorgio,
Have you already tried clearing your appdata? If not please give that a try and post snapshots if you can?
Also, please see if this post helps?
Sandeep
Best Practices to post on the Student Community -
October 14, 2018 at 4:14 pm
Georgiro
SubscriberSo in this case, I need to know, how to clear my data! Because not knowing this, I am not able to do it. Thanks for the detail.
Jiri
October 15, 2018 at 1:06 am
Subscriber -
December 19, 2018 at 7:35 am
Georgiro
SubscriberOk, I do not understand what is the problem now you are speaking about? I just need a help with modelling! So basically you will make me an idiot? Or st. else?
December 19, 2018 at 7:37 am
Georgiro
SubscriberNow, I do not have it related with the license, what is the problem? Why I do not have any access to the quesstions? Is this normal?
2098
1323
1110
461
