May 19, 2021 at 2:27 pm
ybiran
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHello,
I have a client who has a problem importing a step file from one of his suppliers. SpaceClaim refuses to open it.
I tried with another software able to open the steps and it worked (see attached image)
You will find an example of the file in attachment.
Do you know where the problem can come from?Best regards
Yohann
May 20, 2021 at 5:17 am
Charudatta Bandgar
SubscriberHello NOVACAD
Let me look into this, I will get back to you.
Regards.
May 20, 2021 at 1:37 pm
Charudatta Bandgar
Is it possible to get the file in a native file format or in some other format. 203/214/242 are the step file formats that are supported, can you check if the files are saved with this?
Regards.
May 24, 2021 at 2:46 pm
ybiran
SubscriberHello,
The file has been downloaded directly on the website of a standard elements supplier, so I can't know the source of the STEP file and its extension type. In the step extension, is there any other extension than 203, 214 or 242?
After that it's a step file that can be opened in other drawing softwares so it's strange that Spaceclaim can't open it. If I export the file from the other drawing software to re-export in step, it works.
But for the time being, the client has no other software than Spaceclaim at hand...Regards
May 31, 2021 at 11:07 am
Charudatta Bandgar
SubscriberNOVACAD That could be one of the things, I will confirm if that can be checked.
Regards.
June 10, 2021 at 1:32 pm
rg
SubscriberHello Charudatta Bandgar
I have some STEP files that opening them with the 2021R1 version of SpaceClaim open without geometry, while with the previous versions they open correctly
Why?
Best Regards
June 11, 2021 at 5:00 am
Charudatta Bandgar
SubscriberRoberto Can you share the files over mail?
Regards.
June 11, 2021 at 6:14 am
rg
SubscriberCharudatta Bandgar Hello
I sent it to you
Best Regards
June 16, 2021 at 8:31 am
rg
Does the problem happen to you too?
Best Regards
June 25, 2021 at 8:31 am
rg
Do you have any news regarding the problem? The customer asks for news
Best Regards
June 25, 2021 at 8:42 am
Charudatta Bandgar
SubscriberRoberto Hello
I have not heard back yet, I will reinitiate the discussion once again and get you some answers as soon as possible. Apologies for the inconvinience.
Regards.
July 22, 2021 at 2:44 pm
rg
In the latest version of Spaceclaim the problem does not occur
July 22, 2021 at 3:06 pm
rg
SubscriberBut it's random, sometimes it works, sometimes it doesn't
3930
2649
1863
1272
610
