October 26, 2018 at 8:12 am
ybiran
SubscriberHi,
A customer of spaceclaim as a problem with Spaceclaim 19.2 to import step file (or file different than scdoc).
This customer usually double clic on the file in the deskop, normally this action open the file in spaceclaim.
In the 2019.2 version of the software, when they do the same action, they have the error message "no servers provided : ANSYSLI_SERVERS: Flexlm SERVERS:"
I try also and I have the same problem.
In the front version, this action was possible.
Can you resolv the problem ?
regards
Yohann
October 26, 2018 at 8:34 am
Naresh Patre
Ansys EmployeeHello NOVACAD
Please check out below discussion thread for possible solution to this problem.
October 26, 2018 at 3:08 pm
ybiran
SubscriberoK I try to change the key register value and add "/USERUNNINGSPACECLAIM=true".
But when I try to double click on a step file, the problem was always the same !
October 29, 2018 at 5:02 am
Naresh Patre
Ansys EmployeeNOVACAD There are multiple entries in the registry key for spaceclaim. You need to edit the correct entry as listed in below link. Can you check this and try out again?
October 29, 2018 at 10:12 am
ybiran
SubscriberHi,
Ok, effectively i was not in the good registry key ! Now, if spaceclaim is open in my computer, he opens the step file on the new tab. But if Spaceclaim was not open, the problem persist !
I don't know why but it's impossible to force windows to open always step or stl file with spaceclaim. If I do that it's just for one time, even if i tick always open step files with this application.
Regards
Yohann
October 30, 2018 at 5:15 am
Naresh Patre
Ansys EmployeeNOVACAD I will have to check with the team and will get back to you.
October 31, 2018 at 6:34 am
Naresh Patre
I came to know that this is the intended outcome of that modification.
A knowledge article addressing this problem has been published on forum at this link.
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3756
2573
1823
1242
598
