April 30, 2019 at 3:55 pm
ybiran
SubscriberHello,
A customer has a problem with the attached file.
it saves the file in step and when the file is reopened there are faces that should not exist, you can see them in comparison with the images !The file is clean, though!
Do you know where this problem could be coming from?Best regards
Yohann
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
April 30, 2019 at 8:41 pm
Brian Bueno
Ansys EmployeeNOVACAD
There are some problems with the body in the original SCDOC, but I would just repair this problem after importing the STEP file.
- Split the face approximately as shown below and right click on the indicated face and select Detach.
- You will notice a very narrow face pointing into the geometry. Detach this and delete it, then use Fill to replace the missing face. Fill the edges as well to remove them and leave 1 unbroken face.
May 2, 2019 at 2:21 pm
ybiran
Subscriberok, i understand !
Thanks a lot
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3648
2520
1745
1226
578
