October 26, 2018 at 12:04 pm
October 26, 2018 at 12:26 pm
DrAmine
Here are some answers provided about the list of compilers based on the Ansys releases:
You might also want to look into the other link shared by Vishal.
October 26, 2018 at 12:30 pm
Max4
SubscriberThank you but I´ve even read this discussion.
Is it possible to Compile a UDF just with a tool of Visual Studio, and then just Load this UDF in Fluent instead of Build and then Load ?
Maxime
October 26, 2018 at 1:08 pm
DrAmine
Ansys EmployeeNo as the tool will require to know all stuff that Fluent needs: the define macros, the cell access macros,... All of this is quite odd for the tool.
You need to start Fluent from the tool command prompt and compile and work. Please go through the post by Vishal as it is matching your situation:
https://forum.ansys.com/forums/topic/problems-loading-udf-for-moving-mesh-in-fluent/
2688
2138
1355
1136
462
