Ansys Products
Ansys Products
Problem when installing and opening workbench: Ans.SceneGraphChart.SceneGraphAddin
    • zyc05505136
      Hello, I just downloaded and installed the student R1. After installing it and rebooting my laptop, I cannot find "workbench" in my start menu. Then I tried to open a .wbpj file which I got from another computer, and it showed as below:
      ????????????????The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.Exception: SceneGraph.Engine - failed to boot up.
         at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
         at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
         at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
         at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
      I have already updated graphics card driver and try again, ,but the problem persisited.
      I hope you can help me find a solution, thank you.
    • Keyur Kanade
      please check admin permissions.
      please check disk space.
      please check hardware requirements.
      https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Installation and licensing category.
      Keyur
    • tsiriaks
      Do you have install.err file under (default location) C:Program FilesANSYS IncANSYS Student
      If so, post the content of it here.
      Also, open CMD prompt and enter the following command
      "%awp_root201%FrameworkbinWin64runwb2.exe"
      what do you get ?
      Thanks,
      Win
    • aleksandra.mikulikova
      That’s quite an old topic but the same problem occured at my computer today after the installation – so I just want to share the solution with you —> (windows10) change your user account name or add a new one by using ENGLISH  ALPHABET only
Viewing 3 reply threads
