September 13, 2023 at 12:45 pm
Daniel Luongo
SubscriberFor the past few months, I and some of our customers have been experiencing the problem that as soon as we install the new version of the software, trying to start it after a few moments it crashes, disappears... Even after installing the provided patch.The only way to "fix" it is to go through the command prompt and force it open.Can the alternative be found to give to our customers to solve this problem?Thank you in advance -
September 13, 2023 at 1:56 pm
Devendra Badgujar
Forum ModeratorHello Daniel,
This is a known issue with SpaceClaim 2023 R2 and is expected to be resolved soon. Only SpaceClaim is affected because its copy of Microsoft.Identity.Client.dll is slightly different than the copy used elsewhere.
The issue can be corrected by copying Microsoft.Identity.Client.dll from elsewhere to the scdm folder:
Copy from: $(AWP_ROOT232)\Subscription\bin\Win64\Microsoft.Identity.Client.dll
to: $(AWP_ROOT232)\scdm\Microsoft.Identity.Client.dll
The file you want is 1,407 KB. Let me know if this helps.
Devendra
September 13, 2023 at 2:17 pm
Devendra Badgujar
Just a note, this issue is with some subsciption users, and is expected to be resolved soon. Till then, please try using the command line options (run as admin for some) and the workaround mentioned above.
Thanks,
Devendra
September 14, 2023 at 7:50 am
Daniel Luongo
SubscriberThank you Devendra,
I will try this procedure from now on, otherwise I will continue to use the prompt.
September 14, 2023 at 7:55 am
Devendra Badgujar
Forum ModeratorSounds good, thanks Daniel. Let us know if the workaround works for you.
Devendra
- The topic ‘Problem when starting SpaceClaim 2023R2’ is closed to new replies.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7808
4508
2979
1453
1322
