August 3, 2018 at 10:17 am
Sebastian
SubscriberHello together,
I have a problem with a Maxwell 3D Simulation (please see attached file). When Maxwell is solving first it checks the conduction paths and after that it creates the mesh. If the mesh is ready Maxwell sends the mesh file. Then a message appears "3D solver doens't work any more" and Maxwell will shutdown. What could be wrong in the simulation?
Thank you very much in advance
Sebastian
- Maxwell, HFSS or Q3D?
- Error
2610
2088
1321
1108
459
