PROBLEM WITH ANSYS APDL – URGENT-
    • Mohamed SEKKAKI
      Hello. I model a masonry wall using the detailed micro-modeling approach (bricks, mortar, brick/mortar interfaces), after entering the linear and nonlinear behavior of the masonry components, mesh, loads,DOF, and the contact between the elements using (contact pair). I click on SOLVE--> CURRENT LS FILE, the software begins to do the calculations, as soon as the convergence curve begins to appear, the software locks up, stops and exits without any error message.
      SOFTWARE : ANSYS APDL
    • peteroznewman
      Did you run out of disk space?
    • Mohamed SEKKAKI
      No sir, I have more than 1TB of free disk
