August 14, 2023 at 4:14 am
Muhammad Afif
SubscriberHi All,
I already run a Maxwell Transient Cosimulation in Simplorer for 16 ms with the following settings:
Then, I copy and paste the Simplorer design and rename it to a different name. I change the End Time to 20 ms.
Also, in the Design Settings, now I set it to read from a .KRN file created from the previous step.
But when I click "Analyze", these errors occur:
Could anyone please help me with this problem? I have read the manuals of Maxwell and Twin Builder (2023 R2) and still can not find a way to figure it out.
Thank you.
August 16, 2023 at 12:31 pm
HDLI
Ansys EmployeeHello Muhammad,
I do not think this process works for co-simulation. You may use "clean stop" feature in orginal model to restart the simulation.
HDLI
August 18, 2023 at 2:18 am
Muhammad Afif
SubscriberHi HDLI,
But in the pdf file of Twin Builder Help (2023 R2) page 865 (13 - Product Coupling > Maxwell Coupling Components > Maxwell Transient Cosimulation Component > Continuing a Cosimulation with Maxwell), it is said that is is possible to do.
Best,
Nauval
August 23, 2023 at 2:42 am
Muhammad Afif
SubscriberHi,
Is it confirmed that it is impossible to continue a Maxwell Transient Cosimulation in Simplorer or still possible based on the pdf file of Twin Builder Help (2023 R2) page 865 (13 - Product Coupling > Maxwell Coupling Components > Maxwell Transient Cosimulation Component > Continuing a Cosimulation with Maxwell)?
Best,
Nauval
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7592
4440
2953
1427
1322
