LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Problem with controle pore fluid, pore pressures in soils
    • Konstantinos Chatzis
      Hello everybody, I am a PhD student and I am new at using LS-DYNA. My field is geotechnical engineering. I am trying to simulate simple geotechnical examples in order to get familiar with the software. However, I encountered some problems while simulating a saturated material.
      I am modelling 1 3D cube, where the side boundaries are restricted in movement and a load is applied on top. Initially, I checked this model without saturation and the results where the expected (displacement at the top of the cube, horizontal and vertical stresses). However, when I included keywords for saturating the model the vertical stress is equal to zero. This is the case even when the ATYPE is 0 in the keyword *CONTROL_PORE_FLUID.
      I am attaching one input file. I am looking forward to any recomendation. Thank you in advance.
      $# LS-DYNA Keyword file created by LS-PrePost(R) V4.7.17 - 08Jul2020
      $# Created on Jun-28-2023 (18:33:31)
      *KEYWORD
      *TITLE
      $# title
      LS-DYNA keyword deck by LS-PrePost
      *CONTROL_PORE_FLUID
      $# atype wtable pf_rho grav pf_bulk output tmf
      0 0.0 1000.01.00000E-9 9810.0 2200.0 0 1.0
      $# targ fmin fmax conv conmax eterm
      0.0 0.0 0.0 1.01.00000E-41.00000E20 1.0
      *CONTROL_TERMINATION
      $# endtim endcyc dtmin endeng endmas nosol
      1.0 0 0.0 0.01.000000E8 0
      *DATABASE_BINARY_D3PLOT
      $# dt lcdt beam npltc psetid
      0.1 0 0 0 0
      $# ioopt rate cutoff window type pset
      0 0.0 0.0 0.0 0 0
      *BOUNDARY_SPC_SET
      $# nsid cid dofx dofy dofz dofrx dofry dofrz
      1 0 0 0 1 1 1 0
      *SET_NODE_LIST_TITLE
      NODESET(SPC) 1
      $# sid da1 da2 da3 da4 solver
      1 0.0 0.0 0.0 0.0MECH
      $# nid1 nid2 nid3 nid4 nid5 nid6 nid7 nid8
      1 2 3 4 5 6 7 8
      9 0 0 0 0 0 0 0
      *BOUNDARY_SPC_SET
      2 0 1 0 0 0 0 0
      NODESET(SPC) 2
      2 0.0 0.0 0.0 0.0MECH
      3 6 9 12 15 18 21 24
      27 1 4 7 10 13 16 19
      22 25 0 0 0 0 0 0
      *BOUNDARY_SPC_SET
      3 0 0 1 0 0 0 0
      NODESET(SPC) 3
      3 0.0 0.0 0.0 0.0MECH
      1 2 3 10 11 12 19 20
      21 7 8 9 16 17 18 25
      26 27 0 0 0 0 0 0
      *BOUNDARY_SPC_SET
      4 0 0 0 0 0 0 0
      NODESET(SPC) 4
      4 0.0 0.0 0.0 0.0MECH
      19 20 21 22 23 24 25 26
      27 0 0 0 0 0 0 0
      *BOUNDARY_PORE_FLUID_PART
      $# pid wtable pf_rho atype pf_bulk acurve wtcur suclim
      1 1000.01.00000E-9 0 2200.0 0 0 0.0
      *BOUNDARY_PWP_SET
      $# sid lc cmult lcdr tbirth tdeath
      4 0 0.0 0 0.01.00000E20
      $# iphre itotex idrflag table
      0 0 0 0
      *LOAD_SEGMENT_SET_ID
      $# id heading
      1Pressure
      $# ssid lcid sf at
      1 1 1.0 0.0
      *PART
      $# title
      Cube
      $# pid secid mid eosid hgid grav adpopt tmid
      1 1 1 0 0 0 0 0
      *SECTION_SOLID_TITLE
      Cube
      $# secid elform aet
      1 1 0
      *MAT_ELASTIC_TITLE
      Soil
      $# mid ro e pr da db not used
      12.00000E-9 90.0 0.2 0.0 0.0 0.0
      *MAT_ADD_PERMEABILITY_TITLE
      Soil permeability
      $# mid perm
      1 1.0
      *DEFINE_CURVE_TITLE
      Curve_Pressure
      $# lcid sidr sfa sfo offa offo dattyp lcint
      1 0 1.0 1.0 0.0 0.0 0 0
      $# a1 o1
      0.0 0.0
      1.0 1.0
      1.1 1.0
      *SET_SEGMENT
      $# n1 n2 n3 n4 a1 a2 a3 a4
      24 23 20 21 0.0 0.0 0.0 0.0
      23 22 19 20 0.0 0.0 0.0 0.0
      26 25 22 23 0.0 0.0 0.0 0.0
      27 26 23 24 0.0 0.0 0.0 0.0
      *ELEMENT_SOLID
      $# eid pid n1 n2 n3 n4 n5 n6 n7 n8
      1 1 1 2 5 4 10 11 14 13
      2 1 2 3 6 5 11 12 15 14
      3 1 4 5 8 7 13 14 17 16
      4 1 5 6 9 8 14 15 18 17
      5 1 10 11 14 13 19 20 23 22
      6 1 11 12 15 14 20 21 24 23
      7 1 13 14 17 16 22 23 26 25
      8 1 14 15 18 17 23 24 27 26
      *NODE
      $# nid x y z tc rc
      1 0.0 0.0 0.0 0 0
      2 500.0 0.0 0.0 0 0
      3 1000.0 0.0 0.0 0 0
      4 0.0 500.0 0.0 0 0
      5 500.0 500.0 0.0 0 0
      6 1000.0 500.0 0.0 0 0
      7 0.0 1000.0 0.0 0 0
      8 500.0 1000.0 0.0 0 0
      9 1000.0 1000.0 0.0 0 0
      10 0.0 0.0 500.0 0 0
      11 500.0 0.0 500.0 0 0
      12 1000.0 0.0 500.0 0 0
      13 0.0 500.0 500.0 0 0
      14 500.0 500.0 500.0 0 0
      15 1000.0 500.0 500.0 0 0
      16 0.0 1000.0 500.0 0 0
      17 500.0 1000.0 500.0 0 0
      18 1000.0 1000.0 500.0 0 0
      19 0.0 0.0 1000.0 0 0
      20 500.0 0.0 1000.0 0 0
      21 1000.0 0.0 1000.0 0 0
      22 0.0 500.0 1000.0 0 0
      23 500.0 500.0 1000.0 0 0
      24 1000.0 500.0 1000.0 0 0
      25 0.0 1000.0 1000.0 0 0
      26 500.0 1000.0 1000.0 0 0
      27 1000.0 1000.0 1000.0 0 0
      *END
    • Ushnish Basu
      Konstantine,
      I will give the following general  tip that typically, pore-pressure problems use LOAD_BODY and INITIAL_STRESS_DEPTH to include the effect of gravity.
      You can search for the following paper online "Modelling liquefaction of soils with LS-DYNA using a SANISAND-based material model", as it has some discussion of modeling pore-water-pressure problems.
      Also, please be sure to read through the Remarks under CONTROL_PORE_FLUID and INITIAL_STRESS_DEPTH in the latest versions of the manual
      Hi Usnish,
      Thanks for your reply.
      I looked at the paper that you proposed, but I couldn't find an explanation why I should use the Load_Body. I understand the Initial_Stress_Depth, but not the load_Body.
      Another question, if I want to have zero initial effective stresses, how can I achieve that since the water pressures due to gravity are always calculated in LSDYNA?
      Finally, I cannot get the output of the pore water pressures. I read the manual, but I cannot find the right way to get this output. Could you help me also with this?
      Thank you very much.
    • Ushnish Basu
      The INITIAL_STRESS_DEPTH sets the initial stress due to gravity, LOAD_BODY maintains that stress throughout the simulation
      A zero initial effective stress is inconsistent with hydrostatic pore pressures
      The pore pressures are available as a history variables in d3plot and elout - see the section on "Output" in the Remarks under CONTROL_PORE_FLUID
      Unfortunately, I am not able to provide more detailed help in this forum, hopefully other community members can help
      Thank you  very much for your reply. It was already helpful.
Viewing 4 reply threads
