problem with defining expression in CFX
    • hamda
      I  want to define the following equation for energy source:
      410040 [W m^-3]*((t^-0.0639 )- (35424000+t)^-0.0639)
      My problem is that since CFX is so sensitive to dimension I have to rewrite the equation like this:
      410040 [W m^-3 s^0.0639]*((t^-0.0639 )- (35424000+t)^-0.0639)
      But I still can't run and get error.
      It should be mentioned  that in the equation, time is considered without dimension. I mean in the equation just the magnitude of time is important.
      I got these messages:
      In Analysis 'Flow Analysis 1' - Domain 'Solid': Transient analyses require that initial conditions are specified unless an Initial Values file is specified at run-time.
      In Analysis 'Flow Analysis 1' - Output Control: No intermediate transient results files have been defined.
    • DrAmine
      Try with 410040 [W m^-3]*((t/1)^(-0.0639)-(35424000+(t/1))^(-0.0639))
