Photonics
Photonics
problem with example Bandstructure of a magneto-optical waveguide
    • lariv
      I am not being able to run the simulation example: https://support.lumerical.com/hc/en-us/articles/360042038613
      I am having the following error:
      Warning:No data set was found for the result: ::model::bandstructure::spectrum
      Warning:The results from the individual stimulations of '::model::bandstructure::fs_detailed' are of different sizes and could not be saved.
      Error: line 25: Can not find specified member 'fd' in dataset 'null'
      Can anyone help me find the problem? I didn't change the file, just trying to run it.
      Best
    • Guilin Sun
      Thank you for bring this case to my attention. I tested and found that indeed the simulations gave the error messages. The cause is from this line
      size_fs =size(n1(2));
      it should be
      ?size_fs = size(n1);
      since "n1" is a 1D array.
      after the modification, I got
      Please modify it and see if it works for you. I will update online file later.
