January 11, 2019 at 11:08 pm
nuchizono
SubscriberI just got a copy of ANSYS for our university lab and we are hosting the license on our own computer. I downloaded and installed both ANSYS 19.2 and the ANSYS License Manager Center. When I tried to add our license file to the License Manager, I ran into issues with FlexNet. I wasn't told anywhere by my ANSYS rep about needing FlexNet or what FlexNet even was.
In the "View Status/Start/Stop License Manager" tab, it shows the following
Licensing Interconnect: running
Licensing Interconnect Monitor: running
FlexNet Licensing: not applicable
In the "Add a License File" tab, it shows the following
The selected License Management Center option is not valid for license server machines that are set up with the following license manager run modes: Run the ANSYS Licensing Interconnect without FlexNet Run the ANSYS Licensing Interconnect and FlexNet independently Please refer to the Advanced Licensing Configuration Options section of the ANSYS, Inc. Licensing Guide for additional information.
When I try to change the run mode in the "Specify License Manager Run Mode" tab, I get the screen shown in the picture. Do I need to get FlexNet? Where do I get that? Thanks a ton, any help would be greatly appreciated.
January 14, 2019 at 1:55 pm
JakeC
Ansys EmployeeHi nuchizono,
Can you please post screenshots of the following logs:
c:program filesansys incshared fileslicensinglicense.log
c:program files ansys incshared fileslicensingansysli_server.log
Thank you,
Jake
January 15, 2019 at 12:29 am
nuchizono
SubscriberHere is c:program filesansys incshared fileslicensingansysli_
server.log
https://photos.app.goo.gl/ZGyDu4yBhejUMHFH9
I do not have a c:program filesansys incshared fileslicensinglicense.log
which i assume may be the issue.
January 15, 2019 at 12:36 am
tsiriaks
Ansys EmployeePlease post the screenshot here as ANSYS employees are not allowed to access/download files from file hosting server.
The license.log would be generated when the FlexNet tried to start. This means it didn't even try.
Please try killing ansysli_server and ansysli_monitor processes from your Task Manager, then rename the following file
c:program filesansys incshared fileslicensingansyslmd.ini
to anything else (make sure it doesn't end with .ini)
Also, what is the content of the file above ?
You can try installing the license file again after renaming this file.
Thanks,
Win
January 15, 2019 at 8:37 pm
January 15, 2019 at 8:38 pm
January 15, 2019 at 8:42 pm
nuchizono
SubscriberThe contents of c:program filesansys incshared fileslicensingansyslmd.ini are as follows:
ANSYSLI_NOFLEX=1
LICKEYFIL=C:Program FilesANSYS IncShared FilesLicensinglicense.dat
January 15, 2019 at 9:03 pm
tsiriaks
Ansys Employeerename the ansyslmd.ini and reinstall your license file again.
Thanks,
Win
April 15, 2020 at 3:29 am
Sushant
SubscriberOk sir i do that but when i start my workbench in 19.2 the system error "0" occur...and licence file is not uploading successfuly. -
April 16, 2020 at 9:37 pm
tsiriaks
Ansys EmployeePlease create a new thread and post the screenshot of the error. Also, mention in that post if you have Academic (paid) license.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
