Ansys Products
Ansys Products
Problem with Fluent Mesh in System Coupling in Workbench
    • georgia.stuart
      I'm running ANSYS v221 on a Centos 8.3 system. When using a project created in ANSYS on Windows, Fluent used with System Coupling in Workbench returns the following error:
      The mesh opens appropriately in the Fluent GUI and appears to be valid. Any suggestions for a fix?
    • George Karnos
      Can you post the Solver output from the Solution Information?
    • georgia.stuart
      Solution information:
      1) System Coupling
      This file may contain appended logs from a sequence of runs, with the most
      recent output reported at the end of the file.
      Transcript output started: 2022-09-06 15:10:00
      |                          Summary of Coupling Setup                          |
      |                          Coupling Participants (2)                          |
      | Participant: Fluid Flow (FLUENT)                                            |
      |    Type :                                                            FLUENT |
      |    UpdateControls:                                                          |
      |       Option :                                            ProgramControlled |
      |    Region: wall_cfd_coupled                                                 |
      |       Topology :                                                    Surface |
      |       Input Variables :                                        displacement |
      |       Output Variables :                                              force |
      |    Variable: displacement                                                   |
      |       Quantity Type :                              Incremental Displacement |
      |       Location :                                                       Node |
      |       Tensor Type :                                                  Vector |
      |       Is Extensive :                                                  False |
      |       Data Type :                                                      Real |
      |    Variable: force                                                          |
      |       Quantity Type :                                                 Force |
      |       Location :                                                    Element |
      |       Is Extensive :                                                   True |
      |       Data Type :                                                      Real |
      | Participant: Transient Structural                                           |
      |    Type :                                                             MAPDL |
      |    UpdateControls:                                                          |
      |    Region: Fluid Solid Interface                                            |
      |       Input Variables :                                               Force |
      |       Output Variables :                           Incremental_Displacement |
      |    Variable: Force                                                          |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |    Variable: Incremental_Displacement                                       |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |                              Analysis Control                               |
      | Analysis Type :                                                   Transient |
      | Global Stabilization :                                                 None |
      | OptimizeIfOneWay :                                                    False |
      | AllowSimultaneousUpdate :                                             False |
      | PartitioningAlgorithm :                              SharedAllocateMachines |
      |                           Coupling Interfaces (1)                           |
      | Interface: interface-1                                                      |
      |    Side: One        |
      |       Coupling Participant :                            Fluid Flow (FLUENT) |
      |       Region List :                                        wall_cfd_coupled |
      |       Reference Frame :                                GlobalReferenceFrame |
      |       Instancing                                                            |
      |    Side: Two        |
      |       Coupling Participant :                           Transient Structural |
      |       Region List :                                   Fluid Solid Interface |
      |       Instancing                                                            |
      |    Data Transfer: Displacement                                              |
      |       Target Side :                                                     One |
      |       Source Variable :                            Incremental_Displacement |
      |       Target Variable :                                        displacement |
      |       Unmapped Value Option :                                 Nearest Value |
      |       Mapping Type :                             Surface Profile Preserving |
      |       Convergence Target :                                         1.00E-02 |
      |       Ramping Option :                                                 None |
      |       Relaxation Factor :                                          1.00E+00 |
      |    Data Transfer: Force                                                     |
      |       Target Side :                                                     Two |
      |       Source Variable :                                               force |
      |       Target Variable :                                               Force |
      |       Mapping Type :                                   Surface Conservative |
      |    Mapping Control:                                                         |
      |       Absolute Gap Tolerance :                                      0.0 [m] |
      |       Face Alignment :                                    ProgramControlled |
      |       Poor Intersection Threshold :                                5.00e-01 |
      |       Relative Gap Tolerance :                                     1.00e+00 |
      |       Stop If Poor Intersection :                                      True |
      |                              Solution Control                               |
      | Duration Option :                                                   EndTime |
      | End Time :                                                       0.0075 [s] |
      | Maximum Iterations :                                                      5 |
      | Minimum Iterations :                                                      1 |
      | Time Step Size :                                                  5e-05 [s] |
      |                               Output Control                                |
      | Output Control Option :                                            LastStep |
      | Results        |
      |    Type        |
      |       Option :                                                  EnsightGold |
      | Write Initial Snapshot :                                               True |
      | Warnings were found during data model validation.                           |
      | Warning: Participant Transient Structural (CouplingParticipant:Solution 1)  |
      |     has the ExecutionControl 'Option' set to 'ExternallyManaged'. System    |
      |     Coupling will not control the startup/shutdown behavior of this         |
      |     participant.                                                            |
      | Warning: Participant Fluid Flow (FLUENT) (CouplingParticipant:Solution) has |
      |     participant.                                                            |
      | The variable locations of force and heatflow variables for all Fluent       |
      | participants are set to 'Element'. Make sure that this is consistent with   |
      | the setup within Fluent. When importing the SCI file (this includes running |
      | inside Workbench), you can control the locations of these variables by      |
      | using the 'SYC_FLUENT_CONSNODAL' environment variable. For more             |
      | information, refer to System Coupling User's Guide.                         |
      Awaiting connections from coupling participants...
      Elapsed time: 5 min. Still awaiting connection from: Solution 1. If you feel the participant(s) should already have connected, check participant logs and/or abort the run.
      | "System coupling solution stopped before all participants connected. User   |
      | has aborted the run"                                                        |
      Transcript output stopped: 2022-09-06 15:15:52
      Transcript output started: 2022-09-06 15:22:59
      |    Type :                                                            FLUENT |
      |    UpdateControls:                                                          |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |    Variable: force                                                          |
      |       Data Type :                                                      Real |
      |    Type :                                                             MAPDL |
      |    UpdateControls:                                                          |
      |    Variable: Force                                                          |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |                              Analysis Control                               |
      |    Side: One        |
      |       Instancing                                                            |
      |    Side: Two        |
      |       Instancing                                                            |
      |       Target Side :                                                     One |
      |       Target Side :                                                     Two |
      |    Mapping Control:                                                         |
      |                              Solution Control                               |
      |                               Output Control                                |
      | Results        |
      |    Type        |
      |     participant.                                                            |
      |     participant.                                                            |
      Awaiting connections from coupling participants... done.
      |                              Build Information                              |
      | System Coupling                                                             |
      |   2022 R1: Build ID: 3043b37 Build Date: 10 November 2021 11:15:32          |
      |   ANSYS Fluent 22.1.0, Build Time:Nov 29 2021 12:13:18 EST, Build Id:10213, |
      |   OS Version:lnamd64                                                        |
      |   Mechanical APDL Release 2022 R1          Build 22.1     UP20211129        |
      |   DISTRIBUTED LINUX x64    Version                                          |
      |                           Analysis Initialization                           |
      | Failed to retrieve mesh(es).                                                |
      Transcript output stopped: 2022-09-06 15:25:58
      Transcript output started: 2022-09-06 15:41:21
      |    Type :                                                            FLUENT |
      |    UpdateControls:                                                          |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |    Variable: force                                                          |
      |       Data Type :                                                      Real |
      |    Type :                                                             MAPDL |
      |    UpdateControls:                                                          |
      |    Variable: Force                                                          |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |       Location :                                                       Node |
      |       Data Type :                                                      Real |
      |                              Analysis Control                               |
      |    Side: One        |
      |       Instancing                                                            |
      |    Side: Two        |
      |       Instancing                                                            |
      |       Target Side :                                                     One |
      |       Target Side :                                                     Two |
      |    Mapping Control:                                                         |
      |                              Solution Control                               |
      |                               Output Control                                |
      | Results        |
      |    Type        |
      |     participant.                                                            |
      |     participant.                                                            |
      |                              Build Information                              |
      | System Coupling                                                             |
      Transcript output stopped: 2022-09-06 15:44:42
    • georgia.stuart
      Fluent:
      Transcript Start Time:  15:44:09, 06 Sep 2022
      Current Directory: "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent"
      Build Time: Nov 29 2021 12:13:18 EST
      Executable Path: /opt/ohpc/pub/unpackaged/apps/ansys/solj-2022R1/v221/fluent/bin/fluent
      ID    Hostname    Core   O.S.      PID        Vendor
      n0-3  compute-15  4/192  Linux-64  6608-6611  Common KVM
      host  compute-15         Linux-64  5910       Common KVM
      MPI Option Selected: openmpi
      Selected system interconnect: ethernet
      Cortex Process ID: 5418
      License Server Path: 1055@flex.utdallas.edu
      Reading setting file in cache: "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1.set"
      Reading Settings file "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1.set"...
      Warning:
          Warning: The settings file being read was created in Fluent from a release prior to 2022 R1.
                   Backward / forward compatibility is not guaranteed for such files.
                   You must verify that all settings have been applied correctly.
      Reading "/home/gks090020/Testfortitan1_files/dp0/FFF/MECH/FFF.1.msh"...
      Buffering for file scan...
          2176 nodes, binary.
          2897 quadrilateral interior faces, zone  1, binary.
            37 quadrilateral wall faces, zone  5, binary.
            21 quadrilateral velocity-inlet faces, zone  6, binary.
            21 quadrilateral pressure-outlet faces, zone  7, binary.
          1992 triangular symmetry faces, zone  8, binary.
          1992 triangular symmetry faces, zone  9, binary.
            35 quadrilateral wall faces, zone 10, binary.
            68 quadrilateral wall faces, zone 11, binary.
          1992 wedge cells, zone  4, binary.
      Warning: this is a double-precision solver.
      Building...
           mesh
          auto partitioning mesh by Metis (fast),
          distributing mesh
              parts....,
              faces....,
              nodes....,
              cells....,
              bandwidth reduction using Reverse Cuthill-McKee: 505/29 = 17.4138
           materials,
           interface,
           domains,
          mixture
           zones,
          wall_cfd_coupled
          top_wall
          symmetry_2
          symmetry_1
          outlet
          inlet
          bottom_wall
          fluid
          interior-fluidSetting fluid (mixture) ... Done.
       Setting zone id of fluid to 4.
       Setting zone id of interior-fluid to 1.
       Setting zone id of bottom_wall to 5.
       Setting zone id of inlet to 6.
       Setting zone id of outlet to 7.
       Setting zone id of symmetry_1 to 8.
       Setting zone id of symmetry_2 to 9.
       Setting zone id of top_wall to 10.
       Setting zone id of wall_cfd_coupled to 11.
      Done.
      Setting interior-fluid (mixture) ... Done.
      Setting bottom_wall (mixture) ... Done.
      Setting inlet (mixture) ... Done.
      Setting outlet (mixture) ... Done.
      Setting symmetry_1 (mixture) ... Done.
      Setting symmetry_2 (mixture) ... Done.
      Setting top_wall (mixture) ... Done.
      Setting wall_cfd_coupled (mixture) ... Done.
           parallel,
           dynamic zones,
              wall_cfd_coupled
              symmetry_2
              symmetry_1
      Note: 3d, pressure-based, dynamic mesh, SST k-omega, transient case read into
            3d, double precision, pressure-based, dynamic mesh, SST k-omega, transient solver.
      Done.
      Grouping and repartitioning the fluid cell zones to be smoothed...
      >> 4 Stored Partitions:
          P   Cells I-Cells Cell Ratio   Faces I-Faces Face Ratio Neighbors Load
          0     496      25      0.050    1770      25      0.014         2    1
          1     496      29      0.058    1772      29      0.016         2    1
          2     503      33      0.066    1797      33      0.018         3    1
          3     497      19      0.038    1777      19      0.011         1    1
         Collective Partition Statistics:        Minimum   Maximum   Total
         Cell count                              496       503       1992
         Mean cell count deviation               -0.4%     1.0%
         Partition boundary cell count           19        33        106
         Partition boundary cell count ratio     3.8%      6.6%      5.3%
         Face count                              1770      1797      7063
         Mean face count deviation               -0.5%     1.0%
         Partition boundary face count           19        33        53
         Partition boundary face count ratio     1.1%      1.8%      0.8%
         Partition neighbor count                1         3
         Partition Method                        Metis
         Stored Partition Count                  4
      Done.
           1992 groups for partitioning (including overlaps)
           Merging groups across partitions:
            1 0
           Partition 1992 groups out of 1992 cells
      Grouping and repartitioning the rest of fluid cell zones (if any)...
      Migrating partitions to compute-nodes.
      >> 4 Active Partitions:
          P   Cells I-Cells Cell Ratio   Faces I-Faces Face Ratio Neighbors Load  Ext Cells
          0     496      25      0.050    1770      25      0.014         2    1         25
          1     496      29      0.058    1772      29      0.016         2    1         29
          2     503      33      0.066    1797      33      0.018         3    1         33
          3     497      19      0.038    1777      19      0.011         1    1         19
      Done.
      Fast-loading "/opt/ohpc/pub/unpackaged/apps/ansys/solj-2022R1/v221/fluent/fluent22.1.0/addons/afd/lib/hdfio.bin"
      Done.
      Reading from compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.dat.h5" in NODE0 mode ...
        Reading results.
      Parallel variables...
      Done.
      Writing to compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.cas.h5" in NODE0 mode and compression level 1 ...
        Writing mesh ...
              1992 cells,     1 zone  ...
              7063 faces,     8 zones ...
              2176 nodes,     1 zone  ...
        Done.
      Done.
      Writing to compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.dat.h5" in NODE0 mode and compression level 1 ...
        Writing results.
      Done.
       As physics coupling engine is no longer available. Disconnecting socket connection
      Deleting Client...done
      Shutting down Server...done
      Error: Rpc Communication failure during SCAnalysis:GetRestartInitialStepIndex call at cortexmpc.c:912
      Posting ANSYS Product Improvement Program performance data
      Done.
      Performance Timer for 0 iterations on 4 compute nodes
        Average wall-clock time per iteration:              0.000 sec
        Global reductions per iteration:                        0 ops
        Global reductions time per iteration:               0.000 sec (0.0%)
        Message count per iteration:                            0 messages
        Data transfer per iteration:                        0.000 MB
        LE solves per iteration:                                0 solves
        LE wall-clock time per iteration:                   0.000 sec (0.0%)
        LE global solves per iteration:                         0 solves
        LE global wall-clock time per iteration:            0.000 sec (0.0%)
        LE global matrix maximum size:                         0
        AMG cycles per iteration:                           0.000 cycles
        Relaxation sweeps per iteration:                        0 sweeps
        Relaxation exchanges per iteration:                     0 exchanges
        LE early protections (stall) per iteration:           0.000 times
        LE early protections (divergence) per iteration:      0.000 times
        Total SVARS touched:                              369
        Total wall-clock time:                              0.000 sec
      Transcript Stop Time:  15:44:42, 06 Sep 2022
      Total Transcript Time: 0 Minute 32 Second.
    • georgia.stuart
      Transient Structural:
       Ansys Mechanical Enterprise Academic Research
       |   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     |
       *            ANSYS 2022 R1          LEGAL NOTICES             *
       * Copyright 1971-2022 ANSYS, Inc.  All rights reserved.       *
       * Unauthorized use, distribution or duplication is            *
       * prohibited.                                                 *
       * Ansys is a registered trademark of ANSYS, Inc. or its       *
       * subsidiaries in the United States or other countries.       *
       * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
       * documentation CD or online help for the complete Legal      *
       * Notice.                                                     *
       * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
       * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
       * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
       * The software products and documentation are furnished by    *
       * ANSYS, Inc. or its subsidiaries under a software license    *
       * agreement that contains provisions concerning               *
       * non-disclosure, copying, length and nature of use,          *
       * compliance with exporting laws, warranties, disclaimers,    *
       * limitations of liability, and remedies, and other           *
       * provisions.  The software products and documentation may be *
       * used, disclosed, transferred, or copied only in accordance  *
       * with the terms and conditions of that software license      *
       * agreement.                                                  *
       * ANSYS, Inc. is a UL registered                              *
       * ISO 9001:2015 company.                                      *
       * This product is subject to U.S. laws governing export and   *
       * re-export.                                                  *
       * For U.S. Government users, except as specifically granted   *
       * by the ANSYS, Inc. software license agreement, the use,     *
       * duplication, or disclosure by the United States Government  *
       * is subject to restrictions stated in the ANSYS, Inc.        *
       * software license agreement and FAR 12.212 (for non-DOD      *
       * licenses).                                                  *
       2022 R1
       Point Releases and Patches installed:
       Ansys, Inc. License Manager 2022 R1
       Ansys, Inc. Products 2022 R1
       Autodyn 2022 R1
       LS-DYNA 2022 R1
       CFX (includes CFD-Post) 2022 R1
       Chemkin 2022 R1
       EnSight 2022 R1
       FENSAP-ICE 2022 R1
       Fluent (includes CFD-Post) 2022 R1
       Polyflow (includes CFD-Post) 2022 R1
       Forte (includes EnSight) 2022 R1
       TurboGrid 2022 R1
       ICEM CFD 2022 R1
       Aqwa 2022 R1
       Mechanical Products 2022 R1
       Icepak (includes CFD-Post) 2022 R1
       ACIS Geometry Interface 2022 R1
       Catia, Version 5 Geometry Interface 2022 R1
       Parasolid Geometry Interface 2022 R1
                *****  ANSYS COMMAND LINE ARGUMENTS  *****
        BATCH MODE REQUESTED (-b)    = NOLIST
        INPUT FILE COPY MODE (-c)    = COPY
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     4 CORES REQUESTED
        MPI OPTION                   = OPENMPI
        INPUT FILE NAME              = /home/gks090020/_ProjectScratch/ScrF00E/dummy.dat
        OUTPUT FILE NAME             = /home/gks090020/_ProjectScratch/ScrF00E/solve.out
        START-UP FILE MODE           = NOREAD
        STOP FILE MODE               = NOREAD
        CONNECTION TO COUPLING SERVER REQUESTED
          SYSTEM NAME                = Solution 1
          HOST NAME                  = compute-15
          SERVER PORT REQUESTED      = 58765
       RELEASE= 2022 R1              BUILD= 22.1      UP20211129   VERSION=LINUX x64
       CURRENT JOBNAME=file0  15:43:43  SEP 06, 2022 CP=      0.358
      MAPDL is connecting to the system coupling service on compute-15 through port  58765 ...
         ... connected
       PARAMETER _DS_PROGRESS =     999.0000000
       /INPUT FILE= ds.dat  LINE=       0
       *** NOTE ***                            CP =       0.528   TIME= 15:44:08
       The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
       solution.  Command is ignored.
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  15.7355556
       TITLE=
       Testfortitan1--Transient (B5)
        ACT Extensions:
            LSDYNA, 2021.1
            5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
        TYPE=STRI  DIMENSIONS=      248        1        1
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = /home/gks090020/_ProjectScratch/ScrF00E/
       SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
       PARAMETER _WB_SOLVERFILES_DIR(1) = /home/gks090020/Testfortitan1_files/dp0/SYS/MECH/
       SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
       PARAMETER _WB_USERFILES_DIR(1) = /home/gks090020/Testfortitan1_files/user_files/
       --- Data in consistent NMM units. See Solving Units in the help system for more
       MPA UNITS SPECIFIED FOR INTERNAL
        LENGTH      = MILLIMETERS (mm)
        MASS        = TONNE (Mg)
        TIME        = SECONDS (sec)
        TEMPERATURE = CELSIUS (C)
        TOFFSET     = 273.0
        FORCE       = NEWTON (N)
        HEAT        = MILLIJOULES (mJ)
       INPUT  UNITS ARE ALSO SET TO MPA
       *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2022 R1          22.1     ***
       DISTRIBUTED Ansys Mechanical Enterprise Academic Research
       00000000  VERSION=LINUX x64     15:44:08  SEP 06, 2022 CP=      0.539
                ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
       *********** Nodes for the whole assembly ***********
       *********** Elements for Body 1 "fea" ***********
       *********** Send User Defined Coordinate System(s) ***********
       *********** Set Reference Temperature ***********
       *********** Send Materials ***********
       *********** Send Named Selection as Node Component ***********
       *********** Send Named Selection as Element Component ***********
       *********** Fixed Supports ***********
       ********* Frictionless Supports Z *********
       *********** Create FSI Flags ***********
       ***** ROUTINE COMPLETED *****  CP =         1.095
       --- Number of total nodes = 1412
       --- Number of contact elements = 0
       --- Number of spring elements = 0
       --- Number of bearing elements = 0
       --- Number of solid elements = 162
       --- Number of condensed parts = 0
       --- Number of total elements = 162
       *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  15.7355556
       *************************    SOLUTION       ********************************
       *****  ANSYS SOLUTION ROUTINE  *****
       PERFORM A TRANSIENT ANALYSIS
        THIS WILL BE A NEW ANALYSIS
       LARGE DEFORMATION ANALYSIS
       STEP BOUNDARY CONDITION KEY= 1
       PARAMETER _THICKRATIO =     0.000000000
       USE SPARSE MATRIX DIRECT SOLVER
       CONTACT INFORMATION PRINTOUT LEVEL       1
       SUPPRESS THE FOLLOWING ITEMS FROM BEING WRITTEN TO THE RESULTS FILE:
        NONE
       DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
       DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
       WRITE ALL COMPONENTS TO THE COMPONENTS FILE.
       START WRITING AT THE BEGINNING OF FILE file.cm
       COMPONENTS WERE WRITTEN TO FILE= file.cm
       PERFORM A FULL TRANSIENT ANALYSIS
        USING HHT ALGORITHM
       USE SETTINGS FOR MODERATE SPEED DYNAMIC APPLICATIONS
       SECOND ORDER TRANSIENT PARAMETERS
         GAMMA= 0.1000      (ALPHA= 0.3025      DELTA= 0.6000      ALPHAF= 0.1000      ALPHAM=  0.000    )
       USE FIRST ORDER TRANSIENT PARAMETER THETA=  1.000
       NLDIAG: Nonlinear diagnostics CONT option is set to ON.
               Writing frequency : each ITERATION.
       A NEGATIVE FILM COEFFICIENT IS USED AS IS.
       The variables will be mapped with the default mesh shape in the System Coupling.
       DEFINE RESTART CONTROL FOR LOADSTEP ALL
       AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS   -1
       DELETE RESTART FILES OF ENDSTEP
       ******************* SOLVE FOR LS 1 OF 1 ****************
       PRINTOUT RESUMED BY /GOP
       DO NOT USE AUTOMATIC TIME STEPPING THIS LOAD STEP
       USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
       FOR AUTOMATIC TIME STEPPING:
         USE      1 SUBSTEPS AS A MAXIMUM
         USE      1 SUBSTEPS AS A MINIMUM
       TIME=  1.0000
       INCLUDE TRANSIENT EFFECTS FOR  ALL DEGREES OF FREEDOM THIS LOAD STEP
       ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
         FOR ALL APPLICABLE ENTITIES
       WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE ETMP ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE SRFS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE BKST ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE NLDA ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE V    ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE A    ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       NONLINEAR STABILIZATION CONTROL:
       KEY=OFF
       *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
       *IF  ANSINTER_                         ( =   0.00000     )  NE
            0                                 ( =   0.00000     )  THEN
       *ENDIF
       *** NOTE ***                            CP =       1.179   TIME= 15:44:08
       The automatic domain decomposition logic has selected the MESH domain
       decomposition method with 4 processes per solution.
       *****  ANSYS SOLVE    COMMAND  *****
       *** WARNING ***                         CP =       1.181   TIME= 15:44:08
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** NOTE ***                            CP =       1.182   TIME= 15:44:09
       The model data was checked and warning messages were found.
        Please review output or errors file (
       /home/gks090020/_ProjectScratch/ScrF00E/file0.err ) for these warning
       messages.
       *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
            --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
       ELEMENT TYPE         1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
        KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
       00000000  VERSION=LINUX x64     15:44:09  SEP 06, 2022 CP=      1.184
                             S O L U T I O N   O P T I O N S
         PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
         DEGREES OF FREEDOM. . . . . . UX   UY   UZ
         ANALYSIS TYPE . . . . . . . . . . . . . . . . .TRANSIENT
            SOLUTION METHOD. . . . . . . . . . . . . . .FULL
         OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
         NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
         EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
         NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
         GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
         USE SYSTEM COUPLING . . . . . . . . . . . . . .YES
       *** NOTE ***                            CP =       1.186   TIME= 15:44:09
       This nonlinear analysis defaults to using the full Newton-Raphson
       solution procedure.  This can be modified using the NROPT command.
       The conditions for direct assembly have been met.  No .emat or .erot
       files will be produced.
           D I S T R I B U T E D   D O M A I N   D E C O M P O S E R
        ...Number of elements: 162
        ...Number of nodes:    1412
        ...Decompose to 4 CPU domains
        ...Element load balance ratio =     1.050
       SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
       *** DATA TRANSFER INFORMATION ON SOURCE SIDE ***
           SOLVER . . . . . . . . . . . . . . . . . .Transient Structural (Solution 1)
            REGION. . . . . . . . . . . . . . . . . .Fluid Solid Interface (FSIN_1)
            VARIABLE. . . . . . . . . . . . . . . . .Incremental_Displacement (INCD)
       *** DATA TRANSFER INFORMATION ON TARGET SIDE ***
            VARIABLE. . . . . . . . . . . . . . . . .Force (FORC)
       *** LIST MESH INFORMATION ON FSIN/FVIN INTERFACES
           REGION. . . . . . . . . . . . . . . . . .       1
            NUMBER OF ELEMENTS . . . . . . . . . . .     107
            NUMBER OF NODES. . . . . . . . . . . . .     538
            NUMBER OF CORNER NODES . . . . . . . . .     216
       *** ERROR ***                           CP =       1.867   TIME= 15:44:42
       A System Coupling error occurred while the request AssignToken was
       being served.
       NUMBER OF WARNING MESSAGES ENCOUNTERED=          1
       NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
       ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
      +--------- D I S T R I B U T E D   A N S Y S   S T A T I S T I C S ------------+
      Release: 2022 R1            Build: 22.1       Update: UP20211129   Platform: LINUX x64
      Date Run: 09/06/2022   Time: 15:44     Process ID: 6375
      Operating System: CentOS Linux release 8.3.2011
      Processor Model: Common KVM processor
      Compiler: Intel(R) Fortran Compiler Version 19.0.0  (Build: 20190206)
                Intel(R) C/C++ Compiler Version 19.0.0  (Build: 20190206)
                Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191122
                BLAS Library supplied by Intel(R) MKL
      Number of machines requested            :    1
      Total number of cores available         :  192
      Number of physical cores available      :  192
      Number of processes requested           :    4
      Number of threads per process requested :    1
      Total number of cores requested         :    4 (Distributed Memory Parallel)
      MPI Type: OPENMPI
      MPI Version: Open MPI v4.0.5
      GPU Acceleration: Not Requested
      Job Name: file0
      Input File: dummy.dat
        Core                Machine Name   Working Directory
           0                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
           1                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
           2                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
           3                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
      Latency time from master to core     1 =    5.073 microseconds
      Latency time from master to core     2 =    5.088 microseconds
      Latency time from master to core     3 =    4.623 microseconds
      Communication speed from master to core     1 =  3351.41 MB/sec
      Communication speed from master to core     2 =  3427.78 MB/sec
      Communication speed from master to core     3 =  3425.69 MB/sec
      Total CPU time for main thread                    :        1.8 seconds
      Total CPU time summed for all threads             :        1.9 seconds
      Elapsed time spent obtaining a license            :        0.7 seconds
      Elapsed time spent pre-processing model (/PREP7)  :        0.2 seconds
      Elapsed time spent solution - preprocessing       :        0.5 seconds
      Elapsed time spent computing solution             :       31.7 seconds
      Elapsed time spent solution - postprocessing      :        0.0 seconds
      Elapsed time spent post-processing model (/POST1) :        0.0 seconds
      Equation solver used                              :            Sparse (symmetric)
      Sum of memory used on all processes               :       28.0 MB
      Sum of memory allocated on all processes          :     5184.0 MB
      Physical memory available                         :        344 GB
      Total amount of I/O written to disk               :        0.0 GB
      Total amount of I/O read from disk                :        0.0 GB
      +------ E N D   D I S T R I B U T E D   A N S Y S   S T A T I S T I C S -------+
       |                       DISTRIBUTED ANSYS RUN COMPLETED                     |
       | Ansys 2022 R1               Build 22.1         UP20211129     LINUX x64   |
       | Database Requested(-db)  1024 MB    Scratch Memory Requested      1024 MB |
       | Maximum Database Used       1 MB    Maximum Scratch Memory Used      6 MB |
       |        CP Time      (sec) =          1.920       Time  =  15:44:42        |
       |        Elapsed Time (sec) =         61.000       Date  =  09/06/2022      |
    • Rahul Mule
      it is recommended that you build up to the final two-way analysis incrementally, progressively adding complexity with each step. Check if your participant solutions works fine with representative loads. Look at the transcript files for errors if any.
      Please refer Building a Coupled FSI Analysis from Decoupled Participant Problems (ansys.com).
    • georgia.stuart
      The workbench project I'm using runs fine on a windows desktop. The problems only occur when it's on Linux. What do you recommend?
    • Rahul Mule
      Have you tried running other system coupling projects on Linux? Is this error specific to this project?
      is that file built in v221 in windows or previous version used for that?
      Please try running tutorial Oscillating Plate FSI Co-Simulation with Partial Setup Export from Workbench (CFX-Mechanical) (ansys.com) on Linux.
Viewing 7 reply threads
