November 12, 2019 at 2:44 pm
hiepnt21
SubscriberHi all,
when i initial solve with fluent, i get this error, even i set serial or parallel with any case. i already try to reinstall but no change
Yesterday, i run fine but when i using msconfig to unset number of processors. I was set it to 8 (my cpu has 6c/12t), now i set to 8 still cant fix it. Can anyone help me to fix it?
999999: mpt_accept: error: accept failed: No such file or directory==============================================================================
Node 0: Process 10960: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
November 13, 2019 at 1:28 pm
Ansys EmployeePlease can you post the whole error? Basically everything in the TUI window.
November 13, 2019 at 2:38 pm
hiepnt21
Initialize using the hybrid initialization method.
Checking case topology...
-This case has both inlets & outlets
-Pressure information is not available at the boundaries.
Case will be initialized with constant pressure
Node 0: Process 4520: Received signal SIGSEGV.
thats all when i using serial
, with parallel will add other node and mpt error
November 14, 2019 at 9:58 am
Ansys EmployeeOK, that means the case loads OK. Try standard initialisation. Also, how many cells have you got & how much RAM? What's the mesh quality like?
November 14, 2019 at 10:05 am
hiepnt21
I was try all case, standard initilisation or simple case like flow over 2d airfoil,.. I also try to reinstall my windows but no change. My case has ~260k hexa cell and i got 16gb ram. Again, my case already run in my computer like i said, now i just reopen it and got this problem, and i cant run any case now. i dont know why.
November 14, 2019 at 11:58 am
Ansys EmployeeLook for %appdata% and rename the ANSYS subfolder for the version you're using: current release is 2019R3 which corresponds to v195. There will also be a lot more text, load a simple model and post ALL of it.
November 14, 2019 at 12:53 pm
hiepnt21
Subscriber -
November 14, 2019 at 3:33 pm
Ansys EmployeeOK, so what's the full transcript for a simple model? Please post an image of the Fluent launcher window too.
March 12, 2023 at 8:11 pm
ahmed ibrahim
Subscriberplease, do you solve this problem?
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5454
3419
2475
1310
1022
