Problem with fluid flow (fluent) project
    • jpvelez
      Hello. I hope this email finds you very well!
      I have a problem with the project at ansys fluent. After I finish the Mesh step, the setup page is disable and I really do not know why. How can I fix it? I tried update internet explorer and setup firewall but nothing was a solution. I had the same problem with ansys 19.0 and now with versión 18.2.
      Thanks for your comments
      Disable Setup in a fluent project
    • raul.raghav
      Can you open Fluent in serial instead of parallel and verify if that works?
    • Raef.Kobeissi
      Can you please attached the workbench project to inspect.
      Regards
