Problem with generating PDF Report in Fluent 2021
    • Touf_CFD
      Hello guys,
      I'm having an issue with generating a simulation report in PDF in the new version of Fluent.
      It generates the mesh information but can't seem to be able to load the countours and plots in the report.
      I get the following error message :
      CX_HARDCOPY_Window : error opening PNG file
      Is there a way tof ix this issue ?
      Thank you so munch !
    • DrAmine
      Which Fluent version are you using?
      On Which Operating System are you working?
    • Touf_CFD
      I'm currently using Fluent v2021 R1 on Windows 10
      What happens if you display one of the saved contours?
    • DrAmine
      Can you please attach the error message here and add any information printed elsewhere in log file or transcript. Are you using a dedicated graphic card with an actual driver?.
    • Touf_CFD
      When I choose to display a saved contour there is no error
    • Touf_CFD
      The error seems to be that fluent is trying to temporarily save the countour file to a temp folder in order to generate it in the report, but whenever I change the location of the temp file to be chosen in the workbench it still tries to access the old (which doesn't exist), basically it's trying to save in an inexistant folder.
    • DrAmine
      Can you tell me which Report are you now referring to?
      Can you point the workbench to the default temporary folder? Please add a screenshot.
Viewing 7 reply threads
