October 24, 2018 at 9:52 am
October 24, 2018 at 10:12 am
Sandeep Medikonda
Ansys EmployeeHi,
You can try using Virtual Topology, This can help you in reducing the number of elements in the model.
Sandeep -
October 24, 2018 at 10:48 am
Keyur Kanade
Ansys EmployeeHello,
There are limitations on no. of faces of geometry for student version.
Can you please reduce your model? From where you got this parasolid file?
Keyur
October 24, 2018 at 10:54 am
noszetrampki
SubscriberSorry, but I don't know anything about this tool, could you please explain to me how to use it?
October 24, 2018 at 10:59 am
Keyur Kanade
Ansys EmployeeHi,
Please have a look at the following videos. Also please have a look at Cornell University course at https://www.edx.org/course/a-hands-on-introduction-to-engineering-simulations
Keyur
October 24, 2018 at 11:04 am
noszetrampki
Subscriberkkanade,
I loaded solidworks file to solidworks and saved file as parasolid. But I have deleted every redundant solid or surface, but it still not enough.
October 24, 2018 at 11:09 am
Keyur Kanade
Ansys EmployeeHi,
Looks like you have to simplify your model further.
Can you please create test case. Please create a simple box in solidworks and export parasolid. Then import in DM.
Keyur
October 24, 2018 at 11:20 am
noszetrampki
SubscriberHi Keyur,
I did this and it worked.
October 24, 2018 at 11:46 am
Keyur Kanade
Ansys EmployeeSo its no. of faces of your parasolid file. You need to reduce it in solidworks and then export parasold.
Regards Keyur -
October 24, 2018 at 1:09 pm
noszetrampki
SubscriberThanks, I will do that.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2138
1351
1136
462
