February 9, 2021 at 4:07 pm
tianxiao
Subscriberhello,
I am trying to do some co-Simulation using ANSYS CFX with Flownex. Exactly the same like the tutotial, which is recommended from Flownex, I created a .fmu output data for ANSYS CFX to read. As I tried to import the .fmu data, which I got from Flownex, there was an error, as in the figure below, I tried many times to creat this .fmu data in Flownex, but I still got this error, as I tried to read it in CFX
February 16, 2021 at 4:59 pmrfblumen
Ansys EmployeeHi Tianxiao,nAre you located outside of North America? If so, please contact support@flownex.com for support. If you're located inside North America, let me know and I'll direct you to someone who can help.nFebruary 17, 2021 at 4:36 pmmadkins
SubscriberHi Tianxiao,nCan you try using the attached FMU exported from Flownex and let me know if that works?nnFebruary 17, 2021 at 4:42 pmFebruary 19, 2021 at 8:56 pmmadkins
SubscriberHi Tianxiao,nI'm glad it worked!nWe tested the tutorial and didn't experience any errors, this is the FMU exported from that.nHappy Friday!nMilesnn-edit: my hunch is that you may have experienced a read/write permissions issue.nMarch 1, 2021 at 12:41 pmtianxiao
SubscriberHi madkins,I did exaktly the same again according to the tutorial in Flownex, interessting is, i just get a FlownexFMU.fmu with very strange size, I think it might be the problem, but i couldn't understand why I can not get the correct FlownexFMU.fmun
