Photonics
Photonics
problem with interfacing between klayout and interconnect
    • veerpal kaur
      Hi , I am simulating the RING MODULATOR  in AMF Technology from one of the example "AMF_1_RingMod.gds". (link for file:
      https://drive.google.com/file/d/1KMvLglfiNC1Hr3k8Ui_NBLSx6pCRJvkl/view?usp=sharing
      Here , I am sharing design and error in interconnect window.  Kindly help me to solve this issue. I have installed all the library in interconnect.
      1. design:
    • Devika Padmakumar Nair
      Hello, Are you following all the steps here: KLayout Interoperability User Manual – Ansys Optics
      Regards
      Devika
      • veerpal kaur
        Hello Devika,
         I followed all the steps as mentioned in the above link.  Still, I am facing same problem again. Kindly help me to simulate the design in Interconnect.
        Thank you.
      Can you check Is the ONA "analysis type" property set to "scattering data" or "impulse response"? It should be set to "impulse response for this analysis.
    • veerpal kaur
      Hi, I did that.  Facing same problem again.
    • veerpal kaur
      anyupdate about the solution of above problem?It has been a while.
Viewing 4 reply threads
