Ansys Products
Ansys Products
Problem with licence manager
    • toni1398
      When I try to add the licence info this is what appears. What should I do?
    • ANSYS_MMadore
      The LICSERVER.INFO is not a license file. That file should be provided to your ANSYS Account Team or used at the Ansys Licensing Portal to create your license file based on the information it contains.n
    • toni1398
      @toni1398 The LICSERVER.INFO is not a license file. That file should be provided to your ANSYS Account Team or used at the Ansys Licensing Portal to create your license file based on the information it contains.https://forum.ansys.com/discussion/comment/105512#Comment_105512
      how can I create the license file? I am the host managernI did provide it to the account teamn
    • ANSYS_MMadore
      Can you share your account number so I can look into this? Your account manager should work with you and assist with using the Ansys Licensing Portal if that is how they would like you to obtain your license.n
    • toni1398
      1136158n
    • ANSYS_MMadore
      The ASC on the account should have received an email that the entitlements are available and ready to be activated. To activate them, the ASC will need to go to the Licensing Portal (licensing.ansys.com) and activate following this tutorial.nhttps://www.youtube.com/watch?v=7idHWwDVHrc&list=PL0lZXwHtV6OmAST1t6MHMyAM7f1wBXCLr&indexnnThank you,nMattn
    • toni1398
      oknI followed the tutorial and could activate it. but i cant sill open ansysnn
    • ANSYS_MMadore
      1) Please update the version of the ANSYS License Manager, available from https://download.ansys.com/Current+Release.n2) In your C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini file, please reference DESKTOP-P5J4K17 rather than a244a197. You can open the file with a text editor and then save it to your desktop. Modify with the correct hostname, and save it. Then copy/paste it back to C:\Program Files\Ansys Inc\Shared Files\Licensing\ replacing the existing copy.nnThanks,nMattn
    • toni1398
      this?nn
    • ANSYS_MMadore
      Array No, C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini. It probably looks like this:n SERVER=1055@a244a197n ANSYSLI_SERVERS=2325@a244a197nmodify to look like this:n SERVER=1055@DESKTOP-P5J4K17n ANSYSLI_SERVERS=2325@DESKTOP-P5J4K17nnThere may be permissions preventing you from saving directly to C:\Program Files\Ansys Inc\Shared Files\Licensing which is why I suggest saving to the desktop and then doing a copy/paste back to C:\Program Files\Ansys Inc\Shared Files\Licensing.nThank you,nMattn
    • toni1398
      ok thanks, it is workingnanother question:nwhat do i have to do if i want to change the ansys version?nfor example, i need ansys 19.0 but i installed 2019 r1n
    • ANSYS_MMadore
      You can download from https://download.ansys.com/Current%20Release?releaseno=19_0&operatingsystem=Windows%20x64nnThanksnMattn
    • Vishal Ganore
      Toni, Estevez is an ASC for this account. So please contact him for 19.0. He has access to the Ansys customer portal for downloading the product. n
Viewing 12 reply threads
